PERMATEX HARDENED. Its great for gaskets and other stuff.
Exactly.
I found that LOW ODOR Black silicone RTV works great and stays flexible. Scrape or smear it on just so it fills the cloth pores.
Worked great on my rare KLH 33s.
Maybe not. As Brian noted before me:
It may stay flexible but what is the mass and effect on the fact of the driver. All the silicone and rtv compounds I have tried or used compared to the vintage-ar sealant is thick and has high mass.
Just because something stays flexible or you get it to just fill the pores [does not] means the mass is correct.
(I added "does not" to the last sentence as I think Brian inadvertently omitted it, as the sentence doesn't make sense without it as a caution given the preceding sentence. Sorry for the liberty if I misjudged this, Brian, let me know and I'll fix it.)
Exactly. We know that adding mass to a speaker will raise the lowest frequency response curve. This is why I suggested that a filled butyl caulking (about 65% fillers) was inferior to plain, 100% butyl rubber.
Silicones are wonderful adhesives for many purposes, flexible and robust, but they are stiff. Very stiff. Very, very stiff compared to butyl rubber.
The fact is that many others learned in the art of surround reconstruction have written about their EXPERIMENTS, both here and on ClassicSpeakerPages, and their consensus was that Permatex hardens, silicone is stiff and heavy, PVA while lightweight is more rigid than others, etc. and that the only workable solution is to replicate the original butylene rubber as used by AR and KLH. This was science, with comparisons done over time.
I don't mean what follows as snark, as a nasty dig in any way, or in any way pejorative comment on anyone's hearing or taste in speakers. But the problem with redoing a surround is that one usually does not have an A/B comparison of before and after UNLESS it has been measured with a
scientific instrument that provides an
independent and
impartial record of what was then and what is now. Human memory (and this includes mine, BTW) has been documented to be accurate for only a few seconds of acoustic memory. After that it's very fuzzy.
So we literally can't tell the difference in a before/after comparison,
unless something is significantly better or worse; minor improvements or detriments aren't something we can identify, because we're made out of meat, and meat isn't all that accurate because it doesn't need to be. (Meat, however, is pretty good at not being eaten by lions and hyenas, and in making more of itself, which is why there's so many of us roaming the streets in herds.)
So if silicone drops the lowest response by about 10Hz, which is what I recall RoyC mentioning (off the top of my head, again the accuracy of meat comes into play here), one might not hear that unless one is doing A/B comparisons or has charts from instruments that can be compared. I do not believe that the laws of physics are different for different people or in different living rooms, and that loading a surround (or cone) is going to stiffen it and thus negatively impact frequency response.
Not sayin', just sayin'.
