Hey, KingBubba, I was rewinding some AR voice coils recently and wrote it up a little on another post here, and found ANTIQUE ELECTRONICS SUPPLY has the GC TV and Radio cement i needed to make the windings with, and at the same time, also ordered some GC Insulting Coating. It is a syrup consistency sealer with an applicator and all butyl and carbon black, plus lots of non-repeatable bad stuff chemistry, but would work as a substitute for the AR sealer if it were necessary. Wear gloves and have windows open!..... GC pt. no. 10-1762 for 2 oz. size, it's $11.00. I used it on the AR3's woofer cone diffusors to fill the cracks in them that are getting bigger every year. It blends right in and is barely visible when dry.
Uh, no. Hell no. Run away with hands in the air screaming NO NO NO NO NO, a thousand times NO.
I again waste time debunking nonsense which will destroy speakers to protect the unwary.
That product will destroy the drivers by stiffening and hardening the surround, raising Fs, ruining the frequency response. It is NOT butylene rubber!
The Debunking
Unsuitable products are continually resurrected. I don't know why the thread is not read prior to posting nonsense to see if the "substitute" was already addressed and debunked.
The description suggests a viscous synthetic rubber product dissolved in solvent, which
dries or
cures to a firm consistency, and used to replace electrical tape or vinyl jackets (emphasis added):
https://www.alliedelec.com/m/d/6b7ffb0ebba29cd8eb338c4bb58e1bbb.pdf
Heavy-bodied, black insulating coating which replaces insulating tape in applications where wrap-around tape could not readily be applied. This compound dries quickly to a strong pliable finish that will not crack, peel or chip. It is water and oil proof and may be used outdoors to insulate any electrical terminal,connection or wire splice. Excellent for providing insulation on handles, etc. Voltage rating 1400 v/mil (min.)
I verified the ingredients via the MSDS. The product itself is ≈25% "resins" (likely vinyl resins) dissolved in ≈75% solvents (naphtha, hexane, toluene, methyl ethyl ketone):
This product hardens and will stiffen the surround, raising Fs.
EIGHT YEARS AGO I began addressing this very problem with citations from RoyC's work and Classic Speaker Pages.
See, for example,
in this very thread #51 #67, and #120:
How many times is debunking required? How much is enough?
Hardening surrounds ruins the driver's frequency response. This is
fact. It is not disputable, arguable, or debatable.
NEVER USE VARNISH, GLUE, CAULK, VINYL, INSULATION, TAPE SUBSTITUTES, ETC. ON A VINTAGE SPEAKER SURROUND. IT WILL DESTROY THE SPEAKER.
RoyC has well documented at Classic Speaker Pages that hardening the surround of a driver raises Fs. This is widely known, not disputed, and
ABSOLUTELY TRUE, unlike nearly the entirety of what one reads about surround coatings on the interwebs of a thousand lies. The entirety of the issues were meticulously explained there,
earlier in this thread, and in other detailed threads on AK.
These threads tend to run in circles, as earlier debunked material is endlessly recirculated because "helpful" late-comers to the party don't read the earlier postings and instead set forth internet dogma as if it were true.
A simple search with Google can verify all of that information as 100% true and accurate.
I again refer everyone to the "Restoring the AR-3a" document over at Classic Speaker Pages for plenty of information on sealants which is not based in mindless regurgitation of incorrect dogma. RoyC did all the heavy lifting on this, and deserves all the credit. He did the testing of various cements and caulks, proved that Fs was raised with any dopant other than butylene rubber, and that the original dopant is the one to use.
When Roy writes about speaker sealants it is an excellent idea to follow his advice and heed his cautions. To do otherwise will damage your speakers, likely irreparably so.
