How then does the signal get from the guts to the amp output terminals? Printed circuit traces?
With some research, I tried a pair of van Den Hul speaker cables, which is the same brand (supposedly) that Spendor uses to wire internally. Did not like them at all.
I also have gone through at least 10+ pair of speaker cables, some on loan, some I purchased for a good price on line and subsequently resold, a process of trial and error.
I've found a brand that I like after all that and am trying to stay with them.
I'm afraid it's a journey, just like with your Spendors and Ushers and Redgum and....what else?
I wish I could say it was easy, but there is definitely a difference in cables in my experience.
Sure they're wired up, but the wire is not really some speaker cables with strands.
If you believe cables make no difference whatsoever why bother commenting at all?
Just wait until you start trying different power cables. :dammit:
Oh, sorry, thought you were looking for opinions/thoughts.
As a suggestion, if all you really want are affirmative/yes answers it might be good to say that up front.
Carry on.
Meh; but if it gives you peace of mind...
Gonna rewire the inside of the amp too?
Carry on.
I like my suggestion better as it frames the context in no uncertain terms.
Sometimes using the same type of cable can be too much of a good thing, using a dry detailed speaker cable with dry sounding speakers will probably not create a balanced final result. I'd try other brands to help offset some of the compromises one cable will give you over another, its time consuming but can also be fun.
Once my speakers are done, I intend to wire them throughout with the same cable as I use between amp and speakers.
When I first got my speakers, they had normal electrical wiring inside, but I replaced it all with speaker wire, bass woofer first.
It did provide better sound, but it wont do miracles, let it be the last thing you do to improve a system that is the way you want it to be.
And why not rewire the amp too, if applicable.
David, FYI on the standard BE-718 crossover, standard fine strand copper cable is used for internal wiring.
On the upgraded D'Appolito/GR Research crossovers found in all of the US market models, JPS Labs Alumiloy is used: http://www.jpslabs.com/alumiloy.shtml
You could possibly change the internal wiring to match whatever speaker cables you are using, but the shorter the wire, the lesser the sonic impacts tend to be (IMHO and experience). In this regard, I'd tend to focus on finding speaker cables which float your boat, and then possibly upgrade the internal wiring in future if you are keen to tinker with the speakers.
Original crossover:
US model crossover:
