LiquidLovins
What would be a good price for one of these in used working condition? Anything in particular to look out for that might be a common issue?
Yes, the driver boards. Pull the cover off and they're right on top. The original boards (1040) had a tendency to overheat and fry the unit. The newer (F-6013) took care of that problem. Sansui did a recall so there's a good chance they have the newer ones.Anything in particular to look out for that might be a common issue?
Which one? Good info here. https://www.fmtunerinfo.com/sansui.htmlI am considering one of their vintage tuners.
. Sometimes you can buy newly manufactured F-6013 boards as well.
Thank you for sharing this @rickb119! I know it has been 4 years but I just got the 5000A and it does have the F-6013 board so your post took away my stress; learning after buying the receiver, that it may have a board that might go bad.Yes, the driver boards. Pull the cover off and they're right on top. The original boards (1040) had a tendency to overheat and fry the unit. The newer (F-6013) took care of that problem. Sansui did a recall so there's a good chance they have the newer ones.
Don't know what current prices are, but it is a sweet sounding receiver. Good FM reception too.
So................how do you like it?Thank you for sharing this @rickb119! I know it has been 4 years but I just got the 5000A and it does have the F-6013 board so your post took away my stress; learning after buying the receiver, that it may have a board that might go bad.
Love it! My other Sansui is the 771. Had the Solid State 5000 which I sold and regret it. The only issue is the FM light on the 5000A & need to investigate if the bulb is bad or further (hopefully not) complicated issues. Need to get and read the service manual; I think I can tell how to remove the bulb housing but better to read the service manual first.So................how do you like it?
Ok so there is an issue with FM reception. This is not something I’m skilled on so it is now with my tech to evaluate what is wrong and what the fix would be. I like my equipment to be in full working condition and do listen to FM so hopefully this will not be an expensive repair.Love it! My other Sansui is the 771. Had the Solid State 5000 which I sold and regret it. The only issue is the FM light on the 5000A & need to investigate if the bulb is bad or further (hopefully not) complicated issues. Need to get and read the service manual; I think I can tell how to remove the bulb housing but better to read the service manual first.
