Vancouver BC / Lower mainland deal alerts
Sansui G33000 - $9999
http://vancouver.craigslist.ca/van/ele/5163886050.html
For Serious Audiophile Collectors: Rare and Seldom seen For Sale a Sansui G-33000 Pure Power DC Stereo Receiver in very good condition - considered by many as the Holy Grail of the classic Monster receivers. This unit has had a complete total rebuild and is in perfect working condition. Over 100 hours went into restoring this Iconic Audio Piece. Recent G33000's have gone upwards of $7700 and $10,000 USD, and there was a recent listing for $14,000 USD on a major Auction site!
Serious Offers Only! Do your homework please, this is not a fire sale but an opportunity for the serious collector to obtain one of the rarest and most sought after pieces of audio equipment in history.
Rated at 300 watts RMS per channel into 8 ohms.
This is it. "The Holy Grail". The biggest, baddest thing ever to come out of Japan. Bigger than the Pioneer SX-1980, badder than the Marantz 2600. Retailed for $1900.00 in 1979. Built in two pieces. Consisting of a preamp/tuner section and a separate forced air cooled amp section, the assembled monster is stunning.
The preamp tuner section features IF band selection of wide or narrow for both AM and FM. Dual phono inputs with front panel selectable loading control. Triple tone controls and a third tape loop. The dial scale and meters are all super sized.
The amp section features true mono block design with TWO massive toroidal power transformers and associated filter caps. Binding post connections for two switchable sets of speakers and an automatic temperature controlled cooling fan.
From Sansui:
The G-33000 is the largest of the pure-power receivers manufactured by Sansui.
The Straight DC design ensures that sound purity is jealously safeguarded all the way from input through output.
The superb performance specifications - including the highest slew-rate ever attained in a stereo receiver - will attest to the very high technological and quality control standards with which it was created.
Features:
Controls:
Bass
Midrange
Treble
Volume
Balance
Mic Mixing Level
Switches:
Power
Speakers A
Speakers B
Turnover-Bass: 400Hz/200Hz
Tone Defeat
Turnover-Treble: 2.5kHz/5kHz
Audio Muting: -20dB
Loudness
Subsonic Filter
High Filter
Mode: Stereo/Mono
FM Muting
FM Auto Noise Filter
IF Band-FM: Wide/Narrow
IF Band-AM: Narrow/Wide
4-CH/NR Adapter
Tape Monitor: 1, Source, 2
Tape Copy: 1>2, Source, 2>1
Impedance Selector: Phono 1 100k ohm, Phono 1 33k ohm, Phono 1 47k ohm, Phono 2 47k ohm, Phono 2 100k ohm
Selector: Aux, Phono, FM Auto, Dolby FM De-Emphasis, AM
Indicators:
SPEAKERS A
SPEAKERS B
POWER
PROTECTOR
Left Channel Power Meter
Right Channel Power Meter
FM STEREO
Signal Strength Meter
Tuning Meter
AUX
PHONO 1
PHONO 2
FM
AM
Jacks:
Phones 1
Phones 2
Mic
Left Panel Preamp Section:
Pre-Out/Main-In (L, R)
Pre-Amp Power Amp: Connected/Separated
AC Outlet Unswitched (2)
AC Outlet Switched
Right Panel Preamp Section:
Antenna Inputs: FM 75 ohm, FM 300 ohm, AM
Phono 1 (L, R)
Phono 2 (L, R)
Aux (L, R)
Tape 1 Rec (L, R)
Tape 1 Play (L, R)
Tape 2 Rec (L, R)
Tape 2 Play (L, R)
4 CH Adapter In (L, R)
4 CH Adapter Out (L, R)
AM Stereo IF Out
AM Antenna Adjuster
Left Panel Amp Section:
Speaker System A (L)
Speaker System B (L)
Right Panel Amp Section:
Speaker System A (R)
Speaker System B (R)
Rear Panel Preamp Section:
Pre Amp Out (L, R)
Rear Panel Amp Section:
Pre Amp In (L, R)
Main Connector
AC Outlet For Preamp Section
Shipping Weight: 45 Pounds (PreAmp)
Shipping Weight: 71 Pounds (Amp) 30 x 20 x12
Professionally Packaged.
Note two interior driver board covers are missing, does not affect performance nor can it be seen.
For Reference
From Classicreceivers.com :
You'll hear people refer to a vintage receiver sometimes and say "You don't see those around very often". Usually it's hyperbole. With the monster Sansui G-33000 it's not hyperbole. You REALLY don't see these very often. It would be hard to argue that this isn't the holy grail for Sansui collectors much less vintage receiver collectors in general. I recently wrote a post on the holy grail for Marantz collectors which is the Marantz 2600. One of those rare beasts recently sold for just over $6000. Well, the Sansui G-33000 has that one beat as one just sold for $7700 USD! The most recent was, as I mentioned above, for $7700 (USD) in very nice working condition. That is probably pretty close to the market value right now.
Classic Audio Listing: G33000 - $10,000 USD, E bay Listing G33000 - $14,000 USD.
must have cost quite a bit. I saw the price before the auction had started (4 browns) but didn't see the final result. Plus the taxes and fees on top of that... beautiful piece though..
Yup cost me a bit, came with 3 carts too.
