Velodyne HGS-18 Servo Hookup?
M50'sMike
Member
Hey guys, have been on a long road trying to get my HGS-18 to work properly. Got it used 4-5 years ago, got a new driver and servo which helped, but long story short. I want to make sure the driver is hooked up to the servo properly there's a lot of pins on that side and the sub still cannot seem to produce frequencies below 40hz without "popping". It's most definitely the servo misbehaving, it's not a physical pop, it's not bottoming out and still produces the frequency, but it seems like it can't figure out the correct "rpm" if you will so it produces this buffeting. So I want to make sure I have the driver side of the servo hooked up correctly before I go crazier than this thing has already made me trying to get it to do what I know it's capable of. Hoping some of you might have visual aid. Or might have an idea of what's causing this, also curious if there's an unknown leak in the seal of the box that could cause this. Thanks guys.
