Velodyne SPL10 Amp Plate Repair
ChrisP2
Member
Just finished an SPL10 repair for a friend, here are some notes.....
There's a decent video on YouTube that should help, biggest issue is a handful of 33uf caps buried in the power supply that go bad, high ESR readings.
Tear down is not easy.....
Power Supply:
- Power Down/Double Check Unit is Discharged
- Pull The Amp Plate
- Remove the mesh cover on the Amp Board
- Remove the AMP Board from the Power Supply (unsolder the two headers)
- Detach the MOSFETs from the Heat Sink, remove the amp board.
- Replace all of the caps (handful of 33uf's and one 100uf)
- Reassemble
Preamp:
- Remove the preamp board (6 standoffs, 2 POTs, 3 screws)
- Replace C19/C20 (Both bad in my case)
- There's another dozen or so electrolytics that I did not replace
- Reassemble
Couple or hour job to replace $5 in bad parts.
Hope this helps someone out there !
I am in the process of preparing to fix one of these myself. My Velodyne SPL 1000 series ii is completely dead, no signs of life whatsoever. I found this other video super helpful... it is a 4hr long video of a guy recapping an entire Velodyne SPL10BV, with an pre-amp/amp that appears to be almost identical to the SPL10. Some of the components on the boards look slightly different, and the boards are in a different orientation, but you will see the near complete resemblance to the 3 boards in the SPL10. You can literally watch him take the entire thing apart, with his commentary, its a goldmine!
Had the same sub that died 4 or 5 years ago this after having the original amp replaced under warranty.
Had it serviced then picked up another SPL-1200 II that was gone through after failing previously.
Good subs if the problematic components are replaced and upgraded.
Yeah! I'm excited to get it working. Today I discovered the fuse was blown. I replaced the fuse but it immediately blew again when I powered the unit on... possibly a blown MOSFET shorting out. Luckily it is possible to access the MOSFETs without desoldering the entire hot cage / amp section.
It looks like the factory used 85° electrolytic caps in the original video. Replacing them with 105° caps would probably help if they're getting cooked.
I remember seeing a recommendation which replaced the sub plate amp with a solid plate in its place. A separate box was then used to house the plate amp, which was then vented for cooling airflow. Seemed like a good idea to keep the amp cool and isolated from the sub vibrations.
Looks like 1 of the 4 MOSFETs is blown (there is a scorch mark on the heatsink around it, I posted some more info about my findings here but I'm not getting any responses). I don't see any other obvious issues with any other components. I ordered 4x replacement MOSFETs to replace them all if necessary, but what I'm wondering is whether this is likely to be a failure intrinsic to the MOSFET that failed, or if something else might have failed leading to the MOSFET blowing up.
Does anyone have any suggestions before I start swapping out the MOSFETs and power the thing on again? Would greatly appreciate any thoughts.
Just swapping out the output transistors could be a crap shoot. If you had a schematic and or a service manual you could check some voltages.
The driver transistors could be bad also. Or maybe even a chip.
Thanks for the reply! Unfortunately, no schematic. I emailed Velodyne but haven't heard back yet (apparently they do send schematics for old products).
You have to kind of wonder, did something up stream fry the MOFET? It would be a shame to spend money on new ones only to have them fail due to something else being shorted out.
Yeah, that's what I'm wondering. I did buy 4x of the MOSFETs though, so I'm going to start by swapping just the 1 that has the scorch mark around it. If it blows again I will start digging deeper. I used to be more into electronics/circuits like 10-15 years ago, so I am very rusty at this point. Hopefully this fixes it, otherwise I'm going to be learning a lot more about amplifier design/theory to try to fix this (not necessarily a bad thing).
Argh! No luck. I swapped the MOSFET and, once again, the fuse blew the second I turned it on. The issue has to be somewhere else... I'll have to keep researching what other part failures could cause this.
There's at least 2 variations for the 10, whereas most of the final letters on the model number define the finish or remote control options.
You have no idea how much I appreciate you sharing this. It is exactly what I needed! I just bought a SPL-1200 II (SPL12RBG) via auction, condition was clearly disclosed as powers on, no further testing was done. Woofer looked good via picture. There was also a picture showing the blue power light was lit up. So I rolled the dice. Anyway, it arrived I got it out, checked the woofer via equal pressure press test; it was fine. Set parameters of low pass, gain, etc. Hooked up sub cable then plugged it in to power. Turned it on, blue power light was on, I then fed it some signal via LFE. But not much sound, like zilch, when I got my ear close to the woofer there was a little sputtering sound, not quite a crackle, but very low in volume, it was the source material, but very garbled, it increased with increased gain but it was not outputting much sound, only a tiny bit louder kind of a scratchy sputtering, the woofer cone was not moving much at all. I thought the woofer was blown. So then I jump on the net to AudioKarma and google. I quickly find out I need to determine which is the problem? Is it the subwoofer, or is it the amplifier? Most indications were that it wasn't the woofer, and that I could do a 9volt battery test on the subwoof to see if it was operational. So I hooked up the subwoof to the 9 volt, and woofer cone responded with either pushing out or pulling in, depending if I switched the wire on the 9 volt to negative and positive, and vice versa. Ok, so subwoofer seems to be fine. So I start learning about the amplifier in these things via AudioKarma and Youtube. I learn what problems they typically have, and how to diagnose and then fix them. I learn it is possible to fix, but it's not so easy, mainly due to this being a dangerous amp to work on if you are not careful. I also learn about EBC electronics, and hear they have an excellent reputation and deep experience in fixing these Velo amps for a reasonable fee. By this time, I took the amp out of the gloss black cabinet/box, looked it over, nothing looked bad to my amateur eye, well there was a little something, no blown caps, no burn marks, etc, except I think they're resistors, they are labeled as R3 and R4 on the board. Appearance-wise they looked like tan twinkies with different color circular stripes around them, although they were both tan, the colored stripes around them were a bit different from each other. Out of each of the ends of these twinkies, wire legs connect them to the board. They are located right in front of the mesh-side of the aluminum cage near the edge of this top board which the aluminum cage structure sits on top of. The resistor at R4 on the board has a bit of darkening down the length of it, which could be stress or burn marks. Also where both R3 and R4 connectors connect to the board at the bottom of the legs, the wire looks kind of darkened, maybe burnt, or perhaps oxidized; at these junctures where these resistors connect to the board, things are darkened as well. Every other connection point on the board has a very clean silver shine to it. Should I replace these resistors? Could they be worn out or cooked? Could they result in the sputtering low volume from the sub? I took some pictures of the amp as it was, to be able to refer back to it, if necessary. Anyway around this point, I started to try and take apart the aluminum cage for visual inspection purposes within the alum cage. I removed a few screws but then I watched a youtube video, in the comments the owner of EBC electronics chimed in, and advised against amateur DIY on this amplifier because it is so dangerous to work on if you don't know what you're doing. I also saw on EBC electronics that they charge more if someone attempted to fix the amp. I understand that since an amateur could make these amps even more dangerous for the tech to work on. I am trying to get started with this hobby and already have some things to get started. Although today I learned that I need a good solder sucker. But I'm a bit stuck. I'm trying to figure out if I should have a professional like EBC fix it, or if I should try to fix it myself and just be very, very careful? I have successfully replaced some capacitors on Def Tech 7006 tower speakers sub-amp boards. But doing that I never worked on it while plugged in. I only applied power after I replaced the caps and reinstalled the the 7006's sub-amp. I used to do alot of car audio work, and did a good amount of RV electrical work, but to me it seems that 12 volt, and then RV AC & DC was much easier, simpler, and safer, than fixing this Velodyne amplifier. What do you think? If anyone has any advice I would like to hear it. I feel confident I could work on the amplifier without being electrocuted. I feel almost as confident that I could fix this amplifier. I have put back the 3 or 4 screws back that I took out of alum cage. Since I stopped here, I'm hoping can still get the cheaper repair rate from EBC. Or should I just try and fix it?
Damn guys, gonna make me blush :) Full disclosure - I dropped these because of the cogent approach here to getting these units back on the road - and the comradery whilst doing so. I've only been lurking here for a couple (few?) decades, and recalled forgetting my old logon info some years ago, hence my "new" date of 2017. The opportunity to learn new things keeps me coming back.
Now to business. I own one of the few authorized Velodyne repair shops in North America, and while my days are a-b-s-o-l-u-t-e-l-y buried (I hardly have time to help folks on my fave Yammy page), I'd like to try and get more time here on AK. If you folks can bear with my erratic "time online", I'll do my best to get service lit info out there. I also have the most up-to-date list of available new replacement parts available from Velodyne (including their new line of subs). They are spendy :(
Now, I need more coffee and a minute go back & read the posted replies above, including the excellent write-up by ChrisP2.
As a side note, I run a DD18 in my theater room & a DD12 / DD12+ combo in my 2 channel system -all purchased as blown units, refurbed in my shop and now running for years. I'm a fan (these are incremental upgrades as I swapped out / sold my old HGS and SPL subs over the years).
~Mike
