NoTransistors
Dual Turntables Super-Restorer
Is it not Shakespeare who said, "To Hall Effect Feedback Comparator Circuit or Quartz Lock, that is the question."
Serviced and with a warranty and with easy pick up I'd give this a go.looking at various threads on the QL-Y3F around the web many are reporting issues with auto features etc.
that's my only worry. it does seem like a nice TT otherwise, but I'd hate to recommend to him a piece of equipment that can potentially cost him more in repairs than the cost of the actual TT in the long run. in saying that it comes out of a lab serviced with a 1-year warranty, so it might still be worth considering..
and it could be collected in person unlike all my other findings so far, which would have to be shipped in from other countries..
Hello all,
I'm new to the forum. I'm hoping you can help with this:
Just as an example, I've seen a few decent Denon ones, but then I've read that they can be very good TTs as long as everything is working fine.. but as soon as something goes wrong with the electronics etc they're pretty much ready to go in the bin because they are hard, if not impossible, to repair, or spare parts are hard to come by and so on.
So, are certain models/brands to be preferred/avoided based on their simplicity/complexity of build and/or availability of parts/ease of repair etc.? If so, which ones?
Thank you very much for your help.
Thanks for the insight. Would you say QL is a feature I don't need to worry too much about then? This would open up a quite a few more options out there..
thanks for your input. i'll pass it on to him.All electronics will eventually have some sort of issue that needs repair. A great many of the direct drive turntables will run well for decades, however, the one that blows a speed chip becomes toast. I read about Technics 1200's doing that and they seem to be, from an outside observer's point of view, one of the most reliable. Would he consider belt drive. For that money in Europe, you should be able to pick up a used Thorens that will last decades, needing only gentle handling and the occasional belt. The 125/126 frequency controlled models are exceptions to that as they have frequency generator and amp circuits to go bad, but the models using synchronous motors are good candidates for very long life and perform great. I got a Thorens TD150 new in 1974 and still have it, still use it, it still performs flawlessly. The only parts that could likely need would be a new belt and eventually, the phase shift capacitor it has.
Just a suggestion to provide what I think would be the best in reliability.
Shelly_D
thanks for pointing this out.That Pioneer PL-630 I mentioned has the option of turning QL on or off. I confess that I usually leave it on.
But I’ve had numerous DD’s with no QL and once speed was set, it did not deviate. Unless the speed adjust pots needed cleaning.
Personally, I would not make QL a “must have” feature.
thanks will check it outWelcome to the AK turn table forum.
There are good reliable Denon turn table that do not have the troubles that you referred to.
The Denon DP-1200 (L) is an auto lift that uses "frequency detection servo system" instead of the quartz lock.
https://www.vinylengine.com/library/denon/dp-1200.shtml
yes I tend to agree with that myselfServiced and with a warranty and with easy pick up I'd give this a go.
I have the '5' version still going strong and a similar Denon.
I have one of these that I'm trying to sell. It was picked up by a family member at an estate sale and given to me to check out and sell it. It performs quite well. Not as elaborate as the JVC QL-Y55F I used to own, but all in all, a very good deck. All of the auto functions work flawlessly.Awesome. I have come across the JVC QL-Y3F. Is it any good? I'm just worried about the auto-features failing and that kind of stuff...
