Voice coil repair?
nerdorama
AK member
Anyone ever successfully soldered a voice coil wire? Mine is broken right where it begins onto the former. I've asked GordonW what he thinks about it but thought I would also throw it out to the speaker folks here.
Thanks,
John
What ever technique you use, it's sure to be a delicate maneuver. I seem to recall a recent read where the soldering iron tip was modified with a small coil wrap of fine wire leaving just a small tag end off the tip. Then basically just enough solder to tin the tag. Still seems like quite the challenge, especially since your break hasn't left much to work with. Good luck.
I have used conductive epoxy and paint in the past to repair a ribbon driver in an Apogee Centaur. Maybe that is a safer solution than soldering.
I doubt it, you need to get the wire hot enough to melt the enamel. If you can unwind one winding of the voice coil, that would be your best bet and it won't affect the impedance significantly.
This^^
very tedious do it when calm and relaxed.
It's a 2 layer VC and it appears the broken end is the bottom layer so hard to unwind.
It's a 2 layer VC and it appears the briken end is the bottom layer so hard to unwind.
That does make things a bit more difficult then. Can you take a close up picture (or multiple pictures) of what you've got to work with? Then post them on imgur.com and link them in a reply using the <Image> icon at the top of the edit window, this will allow us to see it in full resolution.
Well, finally worked up the nerve and did it. I scraped the wire ends with a sharp exacto, applied a little paste flux, heated the flux and then soldered the wires with some silver bearing solder. Not sure the silver helps that much but I had it. The woofer now reads 3.5 to 3.6 ohms at the terminals. Hope it holds.
View attachment 1748878 View attachment 1748879
Just make sure that the repaired area is well mechanically secured (a drop of epoxy or similar), and that should work just fine.
You will need to make sure that the combination of the glue and the repaired area, doesn't stick up outside the outer layer of the coil pack- so that the repaired area doesn't rub on the top plate when the woofer goes to full excursion. Other than that, it should be great.
Regards,
Gordon.
Got the speaker reassembled and then pulled the tweeter to redo the ferrofluid. After disassembling the tweeter I found that my ferrofluid had migrated out of the tube and was all over the inside of the zip lock bag. I had sealed the tube with tape after doing the T33's in my 103/3's and thought I had plenty. So more fluid on order and project is paused. The tweeter was really gummed up so glad I'm doing this.
I have 5 T33's to rework so I guess I do a T33 session when the fluid gets here.
John
