Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Measure the diameter of the original wire; find the gauge for that size, and order a pound of replacement double build magnet wire with the same gauge. Order less, if you can, since a VC doesn't use much wire.
Also, get the highest insulation temperature rating you can, for the insulation coating. The polyamideimide is quite a bit better (200 degrees C), than lacquer/enamal coatings (just over 105 degrees C). Voice coils can get HOT inside.
