Hey everyone!
I've recently acquired a used VPI 16.5. I contacted VPI with the serial # for their estimate of the age, but looking at it, it can't be more than 10 years old, and opening it up, everything looks pristine.
That said, I had some problems out of the gate, some of which I may have caused by mistake. The turntable stopped on me a few times but after I had I turned on the vacuum before the turntable a few times, and I was rotating the record 5 times before shutting off the vacuum.
Did these mistakes cause the problem I'm about to describe? I don't know. But here's a short list:
1) I took off the cork center and noticed the three screws were very loose, with some sawdust, suggesting stripping.
2) I took off the rest of the plate fixing the motor and arbor/spindle assembly to the top of the machine. I noted the two hex screws on the arbor/spindle assembly were tight as a drum. BUT, big issue for me was the arbor/spindle assembly was wiggling noticeably side to side. Its own up and down sliding action was fine, so the wiggling to me indicated something broken. [I emailed VPI about this].
3) Thinking this was caused by heat and maybe my mishandling, I thought at least I could try the fan mod, described herein the now famous account here: http://www.audiointelligent.com/rcmmuseum.htm and this one here, https://forum.polkaudio.com/discussion/87672/improvements-to-the-vpi-hw-16-5-record-cleaning-machine, here https://forum.audiogon.com/discussions/vpi-16-5-problem-2 and more here: https://www.audiokarma.org/forums/index.php?threads/rcm-modifications.343158/ , and many other posts. Mark D'Ambrosio, paging Mark..... !
So, here are some questions about this mod:
Cutting MDF in a circle. You need a saber saw? I don't own one. What's the process? I did a dry run on some scrap plywood with my Dremel circle tool with their multipurpose bit and it was far from a smooth process. I had to do multiple passes. Not sure I want to chance this on a machine I paid pretty good money for, even used. How about a hole saw? In that case, I have an 88mm square fan. If I use a hole saw bit that's a little smaller, i.e., 3.25" (82 mm), is that alright? Then, how do you position or stabilize the portion of the machine being cut? I want to make a hole in the back, which necessitates taking out the switches in front. I'm not sure how to take that off, the terminals are on there pretty snug.
My best thinking: if I use masking tape, and am careful and slow with the Dremel, I can get a serviceable hole (hehehehe). But seems risky... not cool, given the excellent condition.... I could try a saw hole that's slightly smaller, but does it need to be especially sharp to cut through the MDF.... I could put the hole on the side.
On that note: Wiring the fan to the AC power, or turntable. How do you do that? What's the process?
Maybe when sharing the mods there's a certain level of skill assumed. But hey, I want to stretch a little. I've done all kinds of DIY projects. I just don't want to **** up if I can avoid it. Thanks!
PS: I would like to seal it further, maybe with three layers. Can I put polyurethane sealant right on the MDF, or does it need a primer first?
