markd51
Nyuk Nyuk
Ahh, OK, I see a little boo boo on the wand, and you put a Bandaid on it, OK, no harm-foul, and likely not an issue that is high priority.
Probably mentioned this way back in this thread. See that little Donut Shaped Collar on the vertical Vacuum Tube that the Wand attaches to? Have you ever made any attempt to properly adjust that?
Simple, clamp a record to the Platter, install the Wand Assembly minus the Helical Spring. Adjust that Collar by loosening the Allen Screw in its side, then the goal is to only have the Vaccum Wand "just touch" the Record's surface. No higher, nor no lower in height. When the Wand is swung over upon the record and then let drop. How far does it drop? Does it touch the record? Or does it go far beyond? Like the 3 Bears, you want this adjustment "just right".
That the Wand just touches the record surface.
Once you have achieved adjusting that collar to fine tune Wand Drop Height, lock the Allen Set Screw, remove Wand, replace Spring, you're done!
There is one bad problem that some VPI RCM owners have encountered, and mostly from previous owner or other mis-use, and that can be an upper deck plate being warped from moisture attack and this causes the Vacuum wand to not evenly come in contact with the entire Record's Surface.
All little pecadillos with these toys.
