burmashave
My experience with the clamp is that the more it's tightened down, the more life it sucks out of the music. I am much much happier with a KAB weight. The music is much more alive. YMMV
With my Prime I find using the clamp in conjunction with the rubber washer causes the bass to diminish. However, on the one or two records I have that are quite warped the clamp and washer work great in flattening them so they can be played.My experience with the clamp is that the more it's tightened down, the more life it sucks out of the music. I am much much happier with a KAB weight. The music is much more alive. YMMV
that is the only reason I would use the clamp. mostly, I would try to replace the lp. My experience is it kills and mutes everything across the octave scale. I have a very revealing system. If something is missing, there is no mistaking thatWith my Prime I find using the clamp in conjunction with the rubber washer causes the bass to diminish. However, on the one or two records I have that are quite warped the clamp and washer work great in flattening them so they can be played.
She's a beautyHi fellow VPI fans ,
Just got this early this month . Am still trying to get it set up properly. Am still having some sibilance issues w/ this new arm wand . Did not take me this long to set up when I did it w/ my metal arm wand . I wish I could have gotten the Gimbal version but last minute I changed my mind because my TNT 6 has already a Gimbal bearing tonearm ( Kuzma Stogi REF 313 VTA )
Here is my VPI Unipivot FatBoy w/ dual pivot modification .
I give the record clamp a spin to get things rollingQuestion:
I have some initial belt slippage after I switch on the motor before it finds speed. I assume there's a film or some such on the belt that causes this. I wiped it down but that didn't help. Any recommendations?
MIC
I have always had a touch of "belt chirping" on the Traveler during start up from time to time. More noticeable on the 45 rpm setting. After my once a year belt cleaning and a coat of fresh talcum powder the chirping is minimized but you can see the struggle of the belt slipping for an instant as it tries to get traction.(one Mississippi)Question:
MIC
Curious as to why the change from the OEM motor.Upgrading my HW19 Mk 4 with the SOTA Total Eclipse package. Smooth install but pulley is too short. Thoughts?
I have the periphery clamp - always give the clamp/platter a little push to help it get to speed. Otherwise, I get the chirp chirp from the belt slipping.Question:
MIC
Question:
MIC
Question:
MIC
