WntrMute2
So I've had this now for about 4 months and I'm very happy with my decision. IMO the Scoutmaster model hits a home run. It also had the features I preferred and was looking for in a BD.
With the Periphery Ring and HRX weight it's a dense 55 lb. beast with a reasonable footprint. Take the time to set it up perfectly then isolate it well and you will be rewarded. I'm using it with VPI's JMW tonearm cables and the cover is a Gingko. Not much to maintain on these, could last forever...
Two points to keep an eye on from a long time VPI owner.
1) Keep the inverted spindle bearing lubed with white lithium grease or similar. I'd suggest every 6 months. Once the grease moves away from the ball/thrust plate interface, you are drilling into the thrust surface. Neither the ball nor the thrust plate are easily serviceable by the owner although the ball CAN be replaced with effort.
2) The spike on the tonearm pivot can get blunted or bent over slightly. Do not lube this! Just make sure it remains sharp and straight.
Great table!
