How many pounds of powder do you get from a baby? Is it a 1 to 1 ratio?Make sure it's real talcum powder, cornstarch baby powder does not work well.
Depends if it's a baby piggy vs. a human...How many pounds of powder do you get from a baby? Is it a 1 to 1 ratio?
Cheers
Mister Pig
Depends if it's a baby piggy vs. a human...![]()
Completely normal. I own 3 VPI's and have worked on and listened to many others and they all do it.Question:
I have some initial belt slippage after I switch on the motor before it finds speed. I assume there's a film or some such on the belt that causes this. I wiped it down but that didn't help. Any recommendations?
MIC
One man’s Canadian bacon is another man’s ham...Sorry those are referred to as piglets. Nice try, please come and play again.
Cheers
Mister Pig
Sota did. It will be on my Cosmos. I wonder if I can get another sensor and run it on my Prime.FWIW, I have the Phoenix Engineering kit on mine and wonder why VPI never acquired the rights to manufacture it after Bill Carlin retired and closed PE. Possibly the best belt drive arrangement ever.
I did not know that, VPI dropped the ball on that then and smart for SOTA to pick it up.Sota did. It will be on my Cosmos. I wonder if I can get another sensor and run it on my Prime.
Cheers
Mister Pig
Cheers
Mister Pig
Or they could just offer the AC motor controllers.The current Sota Roadrunner is identical to the one sold by Phoenix. It will measure speed and usage time on any platter but it will not correct the speed. Used in conjunction with one of the "Phoenix" power supplies, feedback is provided between the two units so that PSU can regulate speed based on the Roadrunner tach. The new "Condor" which replaces the original and universal Phoenix Falcon and Eagle PSUs will require modifications to work in the VPI SAMA since the Condor works and is sold in conjunction with a BLDC motor and is designed for a flat belt. Some have already modified them to work with VPIs. I personally would wait a bit, that's what I'm doing.
My guess is that Sota will eventually offer a Condor with a VPI pulley option and a pre-fabricated female plug adapter so that VPI owners can replace the Hurst A/C motor in their SAMA and plug & play like with the old Falcon/Eagle except with the BLDC motor. There are too many VPIs out there for Sota to overlook that source of revenue now that they own the Phoenix Engineering line. They might as well capitalize on their investment.
Their loss. SOTA will have the best belt drive scheme in the business then.Yes, that would be great if the bring back the Eagle & Falcon. They can call it the "Canary" for all I care... just bring it back.
I don't think it will happen though because Carlin said he had talks with Sota early on and they decided on just pairing the PSU with the "better" motor (in Carlin's view).
As a side note, FWIW sadly there is some "history" between Carlin and VPI.
I think this involves a motor upgrade too. But the Eclipse package shows the Roadrunner and Condor
https://sotaturntables.com/product-category/eclipse-series/
OK, I see and I get it.That’s the BLDC motor I was talking about.
