Damn that is nice, glad it is working out for you. It must be exciting to know that the best is yet to come too.
I can't really tell in that picture but is that the version of ET2 with the fine-adjust VTA dial?
Do you mean during play?
As long as it gives you an accurate reference you can adjust around in fine increments - even not during playing - it's a great feature.
My VPI arm is adjustable in this way and I love it for fine tuning but don't mess with it during play. It is capable of on-the-fly adjustments but I just don't want to play with something as delicate as a uni-pivot while playing - I bet the ET is very much the same.
If they still use the Hurst synchronous motors the speed is determined by line frequency vs pulley-to-platter circumference ratio. If so, the speed is only adjustable with a variable freq regenerative power conditioner.
Finally got the Digi cart dialed in and time for a bit of intense critical auditioning.
Thnx:thmbsp:The VPI's OEM 600 RPM motor has been upgraded/replaced with a 300 RPM motor. I don't know what type of motor, if it's a Hurst or something else, that the VPI arrived with; & the previous owner is out of the country. But he did mention on how much this new motor had improved the sound of the turntable. So, I guess, for right now I'll assume the speed of the platter will be correct as I received it.
I gotta say that tonearm you've installed looks very interesting, & I was looking at an HW-19 before I went for the Scout that I now have. Sounds like the tonearm is working out for you.:thmbsp:
Thnx:thmbsp:
The 300 RPM motor should come with a belt pulley double the circumference of the former motor belt pulley.
I'm really enjoying your posts. It's like VPI 101!
Should be fun settling in with this - I could see a table like this being one that you get very comfortable with, maybe comfortable enough that everything else can go.![]()
It's like VPI 101!
Here is the final iteration of my upgraded Scout.
Has any body jumped off the cliff and put his name on a list for the new DD turntable?
Interesting. What is the cylindrical object next to the tonearm pivot location?
