@Coolhandjjl
Good to know the Ortofon guage will work as well.
@Coolhandjjl
While everyone is entitled to their opinions on a Well Tempered Arm, I don’t think it’s helpful to suggest a new arm for solving a tracking error problem that’s most definitely correctable on this arm. None of the various versions of the Well Tempered Arm have tracking issues if properly set up; this is true on the versions that date back to 1985 and to the simplified version of the arm under discussion from the early 2000’s.
Just for clarification, the silver arm being discussed is the first version of a simplified version of a Well Tempered Tonearm. This silver version uses an aluminum tube, not a stainless steel tube, and was made for the Well Tempered Record Player (WTRP). This tonearm does not have an anti-skate dial like the more expensive versions. A later black version of this tonearm was made with a more conventional looking cartridge platform and thicker walled fluid cup. The amount of anti-shaking is changed by the position of the paddle relative to the overhead arm where the nylon line pass through.
As I mentioned in my earlier posting, it looks like your arm is tilted and is not sitting in the center of the fluid cup. When you play your record and the cartridge is correctly set for azimuth, the arm at the back which is attached to the paddle could be tilted which can cause the mistracking. The paddle is not rotating through the fluid evenly and concentrically.
I have a WTRP and I think my cartridge suspension has been damaged from age or abuse during a few relocations over the past twenty years. I approach changing the cartridge with fear as I recall working with the thread like wires and tiny pins as very tricky. I'm not sure I can do it without pulling loose a pin or two and facing trying to solder beyond my skill level. Also, the silk like insulation appears frayed and I can really discern the wire colors anymore. I was wondering if anyone had experience rewiring the arm externally with something easier to work with.
Gee, if you look about nine posts up, you will find my very thorough explanation of how I re-wired mine.I have a WTRP and I think my cartridge suspension has been damaged from age or abuse during a few relocations over the past twenty years. I approach changing the cartridge with fear as I recall working with the thread like wires and tiny pins as very tricky. I'm not sure I can do it without pulling loose a pin or two and facing trying to solder beyond my skill level. Also, the silk like insulation appears frayed and I can really discern the wire colors anymore. I was wondering if anyone had experience rewiring the arm externally with something easier to work with.
@Vintagear Very nice work!-- looks stellar...![]()
I don't think you need to re-wire the arm. Mine looked like yours. Much better now and less noise.
Cardas PCCEG Gold Cartridge Clips
Color Coded Heat Shrink
