Wharfedale Linton Amplifier
..Rank - Wharfedale has had quite a few receivers available back in 70's along with their speakers range. All the receivers were manufactured by Rotel in Japan. Some were manufactured up to specifications and meant to be perfect match for same name speakers and some were simply rebadged Rotel RX. One way or another this receiver is meant to mate with Linton speakers, considering its styling it comes from 1971 -1974 ...
From a previous thread in 2010
That one is probably made by LEAK who were also owned by RANK at that time and were manufacturing in England.
This thread at Classic Speaker Pages has photos of the internals and a couple of the PCB's are marked LEAK.
The Linton Receivers and later units may have been made by Rotel but the pictured amp is a Leak Delta 30
This thread has a photo of the internals of the Delta 30
Thank you so much for your info. Super helpful and informative. Cheers
Would try to open it up and see what went wrong as its not powered on.
The Service Manual for the Delta 30 is available online for free
Test the Fuses with a Multimeter, if you're lucky, that may be why it's not powering on
Thank you for your advice. Hopefully that was the issue. Keep my finger cross!
Cheers
UPDATE
Opened up the case finally after some effort on the wooden parts, however, unable to find any fuse(s) inside. Don't think I could be able to fix it. Any reliable source in the UK for vintage amp refurbishment?
