Wharfedale Owners Thread
Agree that oil cap is the best but you do not need anything like 600 volts. You can easily get by with 50-100 volts unless you are going to try blowing the drivers out of the cabinet. A cap voltage at or below the maximum voltage a driver can take can act as a fuse and save the driver. A 50 volt cap from memory will handle a 100 watts into 8 ohms, from memory. There is acalculator on the web.
I realize they only used like 50VDC caps in most old speakers (and probably most in general), but the way I saw it, the higher the voltage rating, the better-made the cap, ESPECIALLY when you're talking about the old oil caps. Voltage and tolerance. Also, RS Steve had put Russian-made, n.o.s. caps in his early W70's that were like 10% tolerance/400VDC, and he wasn't happy with the results and I think threw Daytons in there or something similar, but Crestwood23 used Russian-made, n.o.s. oil caps in his W90's that were like 5% or possibly even 2% and 600VDC (I think that's what they were), and he's been thrilled with them. And I've read comments from supposed cap experts (or at least cap-KNOWLEDGEABLE guys) who mentioned some caps having more depth in the higher-voltage examples than the lower-voltage ones, and I've been extremely-happy with the high-voltage ones I used (US-made... 1960's 1000VDC oil caps on the mids and 1950's 600VDC ones on the tweeters). And then you have the "Secret Weapon For Large Advents" thread where an AK'er tried 1950's 1000VDC Industrial Condenser oil caps on his pair, and everybody who heard them agreed that they were the best-sounding Large Advents they had ever heard. So, with all of that info in front of me, I figured the higher-voltage, low-tolerance ones were a safe bet. Sony6060 actually helped me pick out mine. He was invaluable when it came to my W90's AND my Fisher.
Lefty: "You can't say his name... That's the rules."
Donny: "**** the rules!"
I think you will find the voltage rating has nothing to do with the result. As for tolerances, a 2% tolerance will be the same whether a 10 volt cap or 10000 volt cap. Maybe someone should take the same series and spec'd cap or a few from different companies and compare.
This is not different than subbing in a 10 watt resister, say carbon comp, for a 1/4 watt carbon comp where the 1/4 watt works with not problem. What can happen if there is a problem causing overheating the 1/4 watt would likely overheat and open saving say a tube, transformer, etc but the 10 watt will not open and the result is a major meltdown of some critical component. Would you sub in a 3 amp fuse in place of a 1 because someone said it sounds better.
I am not going to suggest that some 600 volt cap may not sound better than some other dissimilarly constructed cap in a circuit; I am not mioptic but, there can be unintended consequences. Today with guys dumping big amps on these speakers, something they were never designed to have on them the voltage of the cap may be more important than when they were made. If dumping a big voltage cap in these, I would at least fuse the speaker to replace or add that safety protection.
I can't remember what amp or receiver RS Steve uses on his W70's. I should check. But since the early, alnico-loaded Wharfedale models seem to be so finicky with caps and how 250V polypropylene Daytons and Solens don't seem to work right, there's got to be a reason. Some deny it's got anything to do with the cap material/dielectric material/whatever and blame it on ESR. It seems impossible to get a solid answer on any of this. Whatever the case, I've been very, very-happy with the oil caps in mine. I admit I've wondered about my new Dentons and how long it will take for the caps to wear out in those.
I was wondering if anyone on here can ID my Wharfedales? To me they resemble a W-60. I do not see any model numbers on the speaker cabinet. Is the speaker terminal original? Thanks advance.
See post #230 of this thread.
W60's
Yup, those are W60's, originally-purchased in the Far East, probably by some US serviceman who brought them back home with him once his tour of duty was up. Radio People was a Hong-Kong-based distributor for Wharfedale models at that point. Same quality as the US-sold Wharfedale models. Wharfedale sold MANY speakers to serviceman who bought them at the PX where they were stationed. Dual and Sansui were ALSO big suppliers to armed forces bases in the Far East back in the '60's and '70's.
Very cool! Thank you very much tyeeslayer & Gang-Twanger
Dave
They might be W60B's, due to the ceramic woofer, but still a W60 2-way with the ported cab and cone-tweeter. Same sound more or less. Best with tubes or a tube-like amps/receivers. Fisher, Scott, Dynaco, Leak, etc. Sansui. That sort of thing. Early solid-state will work too, but emphasis on "tubelike".
davelc2, take a close look at the chalk writing on the woofer for a clue to when they were manufactured. Wharfedale did this with a Rosedale a.k.a. w70 I have.
This image shows ;
6/72/12
D/6
which I take to mean December 6th, 1972
This image shows ;
6/72/12
D/6
Wow that's really neat! Thank you for all of information. This site has a wealth of valuable information. Both cabinets have sequential serial numbers as well.
Dave
Dave
Yeah, his should be like '64 or '65, I would think. No earlier than late '63, my guess. It's a 2-way W60 with a ported cab and a cone-tweeter, right? I'd love to know what kind of magnet the tweeter, has (if it's that Super 5 variant cone-type tweeter... If it's not a cone, then it's definitely ceramic, but I've been trying to figure out if they ever made a ceramic version of that Super-5-style cone tweeter or if it was only available in that original alnico form).
Wharfedale w60c internal padding question. I noticed that a lot of differant Wharfedale speaker models has that rock wool internal padding but my Wharfedale w60c speaker does not. Should I mod mine while I am recapping them with Rockwool? I will get some photo's up on my w60c's as soon as my EE repair main gets to them.
Is yours like a dense, white, polyfoam kind of material? If so, then it's probably stock. My W60E's have that brown rockwool (Cheaper stuff than in the earlier models, and not as thick or dense) but I believe my W60D's may have used a white polyfoam/stryrofoam insulation. Can't remember for sure. My W90's have a dense, thick, sturdier type of wool/rockwool insulation that has a white/yellow-white color to it. You'd think it came from England along with the drivers, since that area is all about sheep. They shipped the sand, so why not the insulation as well.
I miss my W90's. Haven't been able to listen to them the past few weeks because I've been burning in my Dentons. I need to find some quality speaker cables on the cheap so I can wire up two sets of speaker runs and be able to A/B the two different models. The W90's have the size/weight thing down, even at some VERY-low volume levels. But I really like the Dentons too. I need stands though. This hi-fi thing is neverending. It's a constantly-ongoing thing. You keep saying to yourself, "Everything will be perfect if I only had THIS", or "I'll be done upgrading once I get one of THESE", but there's always something else, something new or n.o.s. (new/old-sweet :D ) out there to entice you.
you mean...new old stock... I believe Twang?
Nah... New old SWEET. ;)
Oh crap... This is a Wharfie thread.
d1b28959.jpg~320x480
THIS is new/old-stock. :D
picture.php
My Wharfedale w60b speakers show the following one 12uF cap in each speaker. 12uF. I was looking at the inexpensive Russion PIO caps (K75-10 250V 6.8uf PIO capacitor). Has anyone tried them and any opinions?
The next cheapest quality PIO caps Ive seen are the Mundorf MCap EVO Oil . THe biggest they sell are these:
Mundorf 15mfd EVO Oil Capacitor
Mundorf 8.2mfd EVO Oil Capacitor.
Mundorf 3.3mfd EVO Oil Capacitor
So I would need two in series to get to 12uF?
K75-10 250V 6.8uf PIO capacitor is the biggest the Tubestore sells.
