Pio1980
AK Member
Depends, the better ones can go a few Benji's up.Cost???
Huh???The Schlumberger does look like a Thorens doesn't it?
Offhand, Mitsubishi, Pioneer, Sony, Yamaha, Revox Linatrack (tho a rpita to swap carts).Rabco runs more than a few $100. What others? Air bearing types?
The basic turntable unit.Huh???
Lets see we sold Yamaha, Thorens with a Rabco arm, Revox and B&O. The B&O had the lowest wow and flutter and the lowest rumble. but it was the trickiest to keep operating and of course the little plug in MMC cartridges are no longer available. If I were buying new it would be a Bergmann, but as I don't have the space it would probably be a CLear-Audio Ovation TT with the TT5 arm and swing out base for the arm to mount on. But with the prices of European TT's going through the roof I see why you might be interested in the Yamaha. WE didn't sell that many because YAmaha never supported the things they built as they should have. So I would probably pick a Revox. But I'll stick with my old Thorens with the Rabco because they are dependable and easy to set up and maintain has been my experience for close to 50 years. Finding good belts for the TD 125 is the challenge today.
Nobody has mentioned the best ones ever invented????
HK Rabco ST-7 people.
The only one with constant, silent movement, NO tracking error to correct by bumping a motor every now and then, making a 'Bump'.
Listening to mine right now!!!!
Rabco initially only made the SL-8-8E servo arm, usually paired with a TOTL Thorens TD-124-125. They produced the ST-4 integrated ca 1971, a bit of a rarity these days, before H-K acquired them.The original Rabco arm and turntable, I'd agree with you on. When working right. But the HK models, not as great. Not as robustly built. Not as maintainable.
Nearly all of the cylinder media phonographs had linear tracking via lead screw advance. The Edison Diamond Disc players used a lead screw with a pivoted follower assembly including the horn.
Obliquely, yes, as Boutique group.I wonder, why nobody has mentioned the Goldmund Reference yet?
Greetings from Munich!
Manfred / lini
I can only speak for Revox (B790, B795, B791, B291, B291-S, H9)...somewhat. They were manufactured between 1977 and 1992 in not so moderate numbers (B790 ~45.000, B795 ~35.000, no idea about the others). B291 and H9 were bought, and heavily modified (tonearm and bearing mostly), by EMPIRE AG.Which models? Must not have sold many.
(...) SL-QL1, SL-5 (...)
Right! The sensible budget end of the line.Of which the former belongs to Technics' best ones and in my view also is the nicest one in terms of visual appearance. But even the comparatively modest SL-5 is a surprisingly good model, if equipped with a good cartridge/needle.
Manfred / lini
