What determines speaker efficiency?
Good thread. So when we talk of band pass design is that the same as transmission line (TL) design?
I am currently using a couple different models of pmc's. Generally speaking how do TL type speaker designs effect efficiency given the same driver used in a ported bass reflex design. I read something about better driver control down into lower range. In effect the cabinet is adding better response but is this the same as better efficiency?
TL is a ported design.
A bandpass enclosure has the front and rear of the driver inside individually tuned enclosures mechanically limiting both ends of the frequency response curve. These can be very efficient within their tuned frequency band. Think car audio where the woofers are in a box with a plexiglass front, that's Bandpass.
A transmission line enclosure is much more complicated than a simple port. Typically the rear wave energy is forced through a maze of sorts whose dimensions and length are mathematically calculated to yield a specific response. Typically they can produce lower frequencies than the same driver in a sealed or ported enclosure. Think back to the original ads for the Bose Wave radio where they showed the long twisted path the sound goes through, that's TL.
Friends,
I don't understand what determines the efficiency of speakers. I can see that horns, by their nature, are highly efficient. But speaker drivers? I believe I understand (most of) the physics behind the drivers and how they "work," but I just don't understand why, say, a AR3 is inefficient, while speakers like my Wharfedale W-90s -- full of drivers, some quite large -- are highly efficient and are said to mate well with low-powered tube amplifiers, for example.
Thanks for some schooling!
doug
If you poke around the Lenard Audio site you might find some basic info answering your question. And more!
John Lenard Burnett is an audio pro from down under.
http://education.lenardaudio.com/en/
