What Do You Consider "WARPED"
BKville
I'm putting together a list of albums and their condition that I'm going to sell.. And I want to describe everything as close as possible..
So my question is "What Do You Consider To Be Warped"...
Thanks, Brent
IMHO... if the LP is deformed enough that a properly set up tonearm can't track it without skipping I would say that it is definitely "warped"... no question!
Increasing the stylus force to compensate doesn't count in my book.
warped
If the album causes the tonearm to rise or fall to a degree that is visible to the naked eye I'd say the record is warped.
I have several albums that I still play that I consider warped, some set-ups are more prone to playing warped records than others.
Personally I'd avoid selling any records that I think would be considered warped, the buyer may be less tolerant than me and be unhaoppy with them.
KEn
While this is subjective, I'd call a record warped if it has any noticable ripple when it's spinning.
I lean towards the 'anything noticeable' camp, mostly because my b&o TX-2 is incredibly unaccommodating of records with even very minor warps.
That being said, some of the swingin' arm tt's here will track records with large edge warps with little noticeable struggle (save an audible whoosh or whump at the warp site).
I have a copy of The Doors "L.A. Woman" that was so bad that even my Dual 1257/Ortofon OM20E couldn't track it. I had to use a hair dryer to flatten it. That, my friends, is warped!
Tom
Hair dryer...hadn't thought of that! Just have to get one...
PS to OvenMaster: little by little your sig is disintegrating! What's happening? I miss that boucning speaker!
Colortrakker, you are the first one to mention this about the avatar. Consider it fixed! I simply was trying to find one that was "me" and have been having a tough time of it. May as well stick with what the public wants. :D
Tom
revrun beat me to it; my sense of humour is truly warped.
I have heard of people sandwitching minor warped records between two plates of thick glass and applying low temp heat to slowly return them to a playable state. One person I met put the glass in the sun for a 30 minutes to warm the glass. He them put the records between the glass after bringing the glass indoors and worked for him.
Thanks Guys...
My reason for asking is... I have a bunch of albums that you can just see the arm move maybe a 1/16" to an 1/8"... So I wanted opinions to weather this was considered warped.. And others 1/4" which is definitly warped..
Thanks again, Brent
The responses are quite different because of the difference of peoples TT sensitivity and what they would not like to end up with after buying from someone. I have maybe 2 records that are warped per my standards and my TT still handles them with no noise or skips and its tarcking at 2.5 grms.
warped. If it doesnt lay flat by itself. A little warped if it will lay flat with a record clamp. Badly warped, If with clamp on tone arm rides up and down. might seem to play fine. worse than that trash or inspiration for creativity. my standards, my opinion. :smoke: :smoke: :scratch2:
Just bought a record that looked fine. Turns out it has a "bump" on the first track. I'm positive that my old Shure V15VMRIV would track this with no problem, but the Grado Gold set at 1.5g "catches air". :no:
Thatch_Ear.....no RuSsMaN.....no Thatch_Ear.....no RuSsMaN...no Thatch_Ear.....no RuSsMaN...oh hell it's a draw! :rofl:
/d
Long ago, I tried the album clamped between glass in a low oven, closely monitoring, It did help the warp, but sounded muddy afterwards.
