pRC
...wired backwards
Yeah, I read that post.
You just can't trust anyone anymore! Gotta do it yourself.
Seriously, I'm surprised that they did that, but at least they were consistent. As long as the construction and soldering is sound, it probably doesn't make that much difference.
If you rewire it yourself - you can do a lot of things that a manufacturer cannot due to cost constraints, like making your own coax, or teraing down all the iron and adding gaskets to dampen resonances, and replacing the hardware with brass to cut down on magnetic shorting. Like adding little sorbothane shock mounts to all the tube sockets.
But if a manufacturer tried to build to the same quality as Wardsweb or Phil Sieg, well, the amps would be $15k or more, maybe much more. Now I'm getting all contemplative and boring.
I'll try to find your equipment in the gallery, thanks for the reply!
My website with unfortunate DIY history is:
http://www.cognitivEvent.com/
/pRC
/pRC
