I've resolved the switch issues with the LAG-120A and LDM-171. For the LAG-120A, the contacts in one of the poles of the 100kHz switch (4P2T) would not respond to cleaning, but there was an unused pole on that switch so I just paralleled the contacts with the non-working pole. Problem solved. I used the LDM-171 to measure distortion on the LAG-120A and was surprised to see it was around 0.02%. The 'Auto' function on the LDM-171 is a great feature.
Both my benches have the Leader LDM-171, the first one purchased new in the fall of 1990 for bench #2.
I also have the LAG-120A, but only use it when needed in the field, preferring the much lower residual THD+N LAG-126 for use with the LDM-171 as the pair self tests at .001 % THD+N, which is more than perfect for any daily audio tube equipment testing/checking, and that model signal generator also has a very clean selectable square wave output capability, plus selectable balanced or single ended.
I found about 8 yrs. ago on eBay I found both the Leader LDM-171 & LAG-126 in very clean condition attractively priced, and fully factory specification capable, thus purchased them for use on bench #1 to save the existing Tektronix AA-501/SG-505 pair of much, much lower THD+N & IMD wear & tear for HQ performance lower distortion SS audio equipment testing.
If these Leader units that you purchased haven`t been energized in some time, both if internally still in good shape running them for a couple of days nonstop should, barring any failing PS elcaps, should show performance improvement over that time period, at least that has been my experience with my eBay purchased pair during 2 days of continuous self testing.
Though I don`t remember what my purchased new well over 20 yrs. ago LAG-120A`s factory specification`s residual THD-N, or if I even was interested in knowing, as it was, as indicated above for a non critical handy sinewave signal source for use in the field.
Good test equipment did Leader make, at least all my purchased new and used have been.
Enjoy yours.
