If i remember correctly(some days are better than others), Mr Danley suggests the JBL 2225, which while under analysis might offer better bass extension, IMO sounds like ass in the A7, pulling a close second to the 2226. While Mr. Danley might be the "God" of subwoofers, i don't think he ever "listened" to the 2225 in the A7.
It's my WAG that 2225/2226 were designed as direct radiators for ported boxes, where 2225 sounds very good, and 2226 sounds fairly good, but more importantly strokes those impressed with big power handling numbers.
If you want to go Altec on a budget, look for nice clean 421-8LF's, seal off the vent thru the magnet, cut out the aluminum dome and replace it with the vented paper dustcap used on the 416/515 woofers, this will give you full altec cosmetics and significant low end. The LF version of the 421 will stomp all over the 416, 2225 and 2226 in the A7 box in terms of LF, but it's upper midrange can be a bit too forward or bright with the aluminum dome in place (and it don't look right in A7).
I've "listened" to at least a dozen different woofers/drivers in the A7 box. I knew from the start that i was going to use subs, so i was looking for the best mid-bass and low midrange i could get. 515's are pretty awesome, 515-8G(ferrite) was the best of the 515's for mids.
Ultimately i discovered JBL 2035 which was fully on par with the 515's midrange at about 1/5 the price of 515's, and has the flattest impedance curve of any woofer i've seen which makes it perfect for the Altec straight 2nd order crossover networks. I stayed with the JBL's because i at first used a passive network between the horn and A7.
When they're on sale at PE, the Dayton 400 watt cast frame pro woofer is a great deal that works very well in the Altec horn boxes. I also know some guys that have been very happy with some entries from Usher, Goldwood, 18sound, and B&C in their midbass horns. Goldwood makes some very good performing woofers that are visually very hard to differentiate from JBL's from a front view, at a fraction of the cost.
Just my .02 y'all understand...........................
