A-7 is NOT a bass speaker box, it's a MID-BASS horn with a LF cutoff of 80-100 hz.
Some additional LF extension is provided from the massive amount of bass reflex area, but it's really not on par with the output of the horn unless you happen to hit on a setup and room that plays nice with them.
IMO the 416, particularly the ferrite 416-8C is probably the worst choice for a woofer in an A7 box where Altec woofers are concerned.
The 421-8H, or 421-8LF quite admirably outperform the 416 in a horn, the ultimate Altec horn driver is the 515, and you will not install a better woofer in a horn box.
The Dayton pro woofer is just one of many good possibilities for a replacement woofer, there are literally hundreds that will work. The most ideal replacements will have a Qts of less than .24 .
Wow, that's the first time I've ever heard anyone less than happy with their 19s.
Note the OP is dealing with A7's (VOTT).
Read thru the threads on 19's at the Altec user's board and you'll discover that late model 19's using 416-8C have unsatisfactory bass response among most owners who have heard the earlier alnico versions.
The 416 has a rather loose/floppy suspension and damping, with too small of a motor to damp/control it properly in a big box........... 19 owners will tell you that room placement is critical in getting the sound "right".
I've owned all 3 versions of 416 and have used them in several different boxes and tunings including 19 clones.................. i no longer own any 416's, and i don't seek them or buy them when the opportunities arise, been there, done that.
I ultimately settled with JBL 2035's in my A7's as they offer the closest midbass "punch" to the 515, yet play well up to a higher XO which i prefer. The 2035 is a better "sounding" woofer than the 2225 or 2226, but has a lower power rating and 3 inch voice coil. The 2035 also has a ruler flat impedence curve in it's working range and doesn't require a zobel or smoothing of any kind.
Just my .02 y'all understand.............
