MarmotDavid
I've got a new pair of Magnepan 3.7i's. Currently I'm using my older, unrestored Counterpoint SA-1000 tube/hybrid preamp and and old solid-state Conrad Johnson Sonograph SA-250 power amp. The setup sounds pretty good but I'm sure it could be improved with some newer preamp and power amp, so I'm looking to upgrade these aging electronics. I don't feel I'm getting the best out of these great speakers with this level of preamp and power amp
I'm willing to spend up to about $6000 on a new combination of a preamp and power amp. I have a medium sized listening room and I generally don't listen at really loud levels, so I'm not interested in really beastlike power amps or mono blocks. I like a detailed, warmer sound with good soundstage and very present vocals at moderate levels, if that helps. I need a MM phono stage, Maybe some combination of tube and solid state? I might even consider a big integrated if I knew it worked well with the Maggies. Also, I would definitely buy used if necessary but would probably avoid anything unrestored if it is over, say, 15 years old.
Please let me know all your ideas and comments. All will be appreciated. Thank you.
