What TT's do you folks have
this is first play on my new TT - Still a Thorens TD1601 but with an improved arm.
With an Ortofon 2M Black. A fairly new Thorens model that looks like an old model - stylish I would call it
The arm on the EMTs we had at Danish Broadcasting Corp. in the old days must have been the model for this arm - So much so that the arm on this one is almost a clone of the EMT arm in terms of design.
Sansui QR X7 - makes it 5 turntables which include a Pioneer PL 518, Hitachi HT 500, Sansui SR 525 and JVC QL Y5F. Replaced the tonearm belt and good to go, Seller had it for a few years but never used it owing to no cartridge. The original owner he purchased it from stored it for quite some time so it never had any real play time until I set it up, mounted an Empire 4000 XL 1 for now, not sure what cartridge would be a good fit.
Had to disassemble the control buttons and reglue everything as it is a common issue having them fall inside, especially the power button.
Assuming tonearm might be medium mass on the low side. Paid 350.00 which seems fair given condition and rarity. Possibly Sansui's best effort outside of the SR 929?
SL1200 MK2 W/ Grado Opus3
LP12 Valhalla power supply W/ Nagaoka MP200. New bearing. Sub chassis and bottom plate from Stack Audio. XTC brass counterweight for Basik LVX arm.
RS LAB400 W/ Grado ME+ mono
Pioneer PL570 recapped and new tonearm motor W/ Shure M95 -LP Gear Vivid Microline stylus
Here's my Systemdek IIX with Michell branded Rega RB-300 tonearm. Mnpctech footers, Isokinetik acrylic armboard, Isokinetik "Isovert" VTA adjuster, Michell "Fingernut", "underslung" Isokinetik ISOweight counterweight, nitride ceramic ball bearing. Yup, threw a bit of money at this turntable due to an intermittent "thumping" noise that eventually turned out to be improper tonearm cable dressing where it exits the bottom. That's all sorted now and the turntable sounds great!
I had a IiX in black like yours, it had a Linn Basic Plus arm, i ran it with Dynavector 10x4 cart. It was on what looks like what you have. A Target wall mount, but no butcher block.
I also had a Systemdek II, the biscuit tin model.
I regret selling the IIX. That table really did a nice job, and got up and made music!
Brings back some great memories…
Sounds like you have done some great upgrades to yours.
I have an underslung XTC counterweight for my current Well Tempered Classic V.
Thanks for sharing, and happy listening!
:jump:
Celadon
Always like the AR tables! Never had the chance to own one though…
I see some DBX units hiding to the left, I own a 224, which looks a lot like your lower unit, type II for cassette, and a type I 150 for R2R.
Both are collecting dust, at the moment.
Thanks for the share, and happy listening!
Celadon
In 2013 when I first set-up my ultimate-system and probably my last system, I was using the original classic Technics SL-120. I equipped two of them both with S.M.E. Pre-Improved arms. I was still using a AT-440MLa and AT-150MLz I bought in 2003. I enjoyed what I thought at the time to be excellent sound.
In 2014, I tried these tables with the Denon DL-301Mk.II. I didn't make any change except for the new addition of the cartridge’s superior sound quality. The better sound quality prompted me to strongly reconsider the wonderful world of moving-coil cartridges. A world I strongly rejected due to the high costs from when I started out in Hi-Fi in 1967.
I went on to listen further and wondered why I denied myself a better playback sound for so long. Beyond the elevated costs, I was just being stubborn.
Fast forward to the present and I find there’s still no need to upgrade my tables. I find these early introductions of direct-drive tables satisfying and they were the first in addition to the SL-1100 and the SP-10 way back in 1970-72. In 2018 I purchased two minty SL-1100s that I use in my second system. I chose the SL-1100s for a c=second system because of the specular performance I received with the SL-120’s. When first introduced, I disliked the SL-1100 until I mated it with an arm I always knew I could only dream of, the Dynavector 505. I felt since their introduction, the Technics tables in 1972 were too industrial looking for my tastes so, I bought a Tannoy-Micro-Seiki TM55 in 1974. Still have it, don't use it and it needs new caps.
Presently, the two tables shown are still mounted where they were with the two AT cartridges mentioned above.The only changes were better quality cartridges. The only change was better sound quality because of the better cartridges. I learned that if the table is on par in giving good quality performance in the first place, a better cartridge and tone arm will shine thru regardless.
FM
Below: First setting up of my ultimate system in early 2013.
FM
Below: Three years later, same old SL-120's but, with a Lyra Delo and Lyra Kleos and better work lites. Added additional factory S.M.E. arm counter-weights.
FM
Below: The almost overbearing 'Dynavector 505 tonearm on SL-1100.
FM
Below: SL-1100 + new acrylic arm board with a Grace 840 arm I modified to use with heavier carts. plus a Ortofon Cadenza Blue.
FM
P.S. I still have my very first TT I purchased in 1967, a Garrard entry-level 40B. I had just started working in Manhattan and couldn't afford anything else. In kit form I bought, a Dynaco PAS-3X pre-amp and Dynaco ST-35 tube amp. Bought two empty speaker enclosures on Cortland St., aka 'Radio-Row' just before they knocked it all down. I installed my old Fender Bassman's two 12 inch drivers and bought two RS exponential 7" horns. It was entry level but, sounded better than the family's Magnavox console. Then the service took me away in 1968 but, when I came back I went almost hog-wild in this hobby. I bought a new AR-Xa TT and a Shure M55 in '72 and in 1971, two new AR-3a's.
FM
4m
I had posted this Lenco idler drive here in 2012 when it was all black. It has a Mirko stainless bearing upgrade and MG-1 air bearing linear arm. Several years ago, I got tired of all black and did a Maple wrap with Walnut corner accents.
I was a beta tester for the Phoenix Eagle 25-watt power supply, so it sports that and a Roadrunner tach. I'm a button press away from 45RPM. AT33PTG/II cartridge, Parks Audio Budgie SUT, Bottlehead Eros.
A friend has a Mapleknoll table and told me about this wow and flutter app. My Lenco measures up pretty good. Compressor in basement controlled by key fob. Bulkhead fitting in phone/lan wall plate for air line. Eros has upgraded crotch walnut base.
