Where to find Dynaco A35 surrounds?
Tom Benner
Outdoorsmanydays
Do you know where to find Dynaco A35 surrounds? Also, the unusual (rubber frame)/moulding holding the woofer in place is broken in pieces with the rotted surround.
Thanks,
Neofight
When I can't readily find a replacement I'll measure the following, then search current listings for surrounds that are approx. the same diameter.
Outer diameter of existing surround.
Inner diameter of existing surround
Roll width
Cone diameter
I get measurements in both inches and metric.
Be sure to get either a flat inner edge or filleted if it's angled where it attaches to the cone.
Right, thanks. What I can't seem to find is on the edge there seems to be a rubber round piece holding the woofer in place that surrounds the driver. Here is a pic.
It came off in pieces. I don't know what it's called. Thanks for your help. Anyone?
