Are you starting with an old amp, or from scratch? Are you locked solid with any certain output tube? Do you already have the OPTs?:scratch2:
My first thought from what you have and what I would build is using the Edcor outputs
and run 6V6 in SE UL, with maybe say a 12AT7 or 6BK7 as a driver and 300v supply, if
your power tranny's have the heater current an whatnot there is a lot of output tubes
that could plop in where the 6V6 is, way to many to list that have the same pinout.
EDIT: found an older post of mine..
(amp circuit here) (6SL7 would take a different operating point)
Here is a link to a post I had where the OP built the amp, same thing as above but it's
using a cheap 6BK7, 6BQ7, 6BZ7 for the driver, the above or any of these would work.
http://www.audiokarma.org/forums/showpost.php?p=2608400&postcount=25
Yes I have to admit I'm fond of a good UL setup..
The Edcor 5K 8ohm(or whatever speaker impedance you run) have the UL taps and I've
run quite a few very simple scheems like this with very satisfying results, it is the same
basic circuit as the 6LU8 amp, you also heard the electrocution device at the fest with
those EL500, 6GB5 tubes..
(If you need/want more drive, replace the drivers cathode resistor with an LED)
that could plop in where the 6V6 is, way to many to list that have the same pinout.![]()
I am the OP Kegger is referring to. I couldn't be happier with it. I use it with my computer and some unknown drivers that fit the holes in a pair of Baby Advent cabinets I had. I think it sounds very good and can play at volumes beyond what I'm comfortable listening to with what I imagine are fairly inefficient speakers. Here is a link to the original thread if you're interestred.
http://www.audiokarma.org/forums/showthread.php?t=218792
John
Thanks for the replies! The power trannies that I have on hand are a 300-0-300 90ma ( was thinking that with sand rectification i could squeeze a stereo amp outta this), (2) 250-0-250 pt's -- don't know current capacity on these but I think it is not much as they got very hot on a Maggie SE amp i built-- I was thinking monoblocks for these, and a 350-0-350 pt which came off a pp mono amp. I want to use these before I spend more for power trannies.....the wife has been fussing about the money i spend on this hobby!
