Hey STAN!
YU know u can do what I did with my "tube tester" amp.
Run a 5Y3 for 6V6 tubes. (should get u about 305 volts)
(there are a few slow warmup 5Y3 tubes as well)
Use the 5V4G for the 6L6 and 6L6G tubes. (lesser 6L6's)
Then use 5AR4 for some 6L6GC tubes, and if you have the
heater + B+ current you could run EL34 and KT88's in there.
(plenty of other tubes with the same pinout here as well)
That is the nice thing about that rectifier pinout, you can get
a decent amount of different voltages using different rectifiers.
(even more rectifiers if the 5v winding handles 3a on it)......
That drivers pinout can use a bunch of different drivers just as
the output tube pinout can with those socket wirings you have.
(yah a tube rolling nightmare, or blessing however you look it)
After a while you can tweak that first cap in the supply to work
with your rectifier choices to find a happy medium with swapping
out the rectifiers to work well with quite a few output tubes there.
6L6 tubes can have a very nice tone to them, glad you like them..
