I have an AU-819 that was tuned up by Glenn/EW, and also an AU-919. I used to have an AU-719. These amps are all very nice, hard to go wrong with any of them.
AU-719: 90wpc
AU-819: 90wpc
AU-919: 100wpc (some sources say 110wpc)
The AU-819 is by far the most rare in this series and may have been in production for less than a year (not sure about this). It is curious that Sansui had two 90wpc amps in their line at the same time.
The AU-819 (and 919) have the option of separating the pre and power amp sections, whereas the AU-719 does not. The AU-819 also has the MC/MM phono section options like the AU-919. The AU-819 has a loudness switch, whereas the AU-919 does not.
Here's some more info about differences among these models that I gleaned from the archives here:
"Besides the 819 having the loudness switch instead of the 919’s muting switch, the controls are identical. They both have the nice MC phono preamp circuit. They have the same exact driver board and the same heatsink casting. However, the 100wpc 919 has four Sanken output transistors per channel, but the 90wpc 819 has just two trannies per side.
The 919 has separate transformers for the preamp and amp sections (torroidal), compared to the 819’s big el-core with separate windings. Although both have four 15000µf filter caps, the 919 has the larger oval ones also seen in the G-9000 receiver.
I think it is fair to say that the 819 is a “lower-powered” 919. On the other hand, the AU-719 is clearly an updated (DD/DC circuit) AU-717. The list prices in 1979 were: 719 - $575; 819 - $700; 919 - $800."
When Glenn/EW tested my AU-819, he found that it produced about 120wpc at .009% distortion, about 30% more power than advertised. This was before he rebuilt the protection circuit or set the bias and offset! I think this conservatism about power output is common to other Sansui amps of the time, and also to other manufacturers, e.g. Kenwood.
The AU-717 seems to be the Ford F150 of the Sansui line. The sold tons of them, apparently, judging by how often you see them come up for sale. People seem to love them but problems with glue melting and damaging other components appear to be common. Compared to amps in the -19 series, the AU-717 is said to sound a bit warmer and "fat", whereas the -19 series are a bit more refined and detailed.
I'm currently running the AU-819 in my main system while I wait for quadbob to finish a complete recap of my AU-D11 II. There has been a long-running and probably never to be resolved debate about the merits of recapping, so I am looking forward to hearing how it sounds. That model is known to be a major PIA to set up right, but that is another thread...
