I've always felt that the best dynamics came from large efficient speakers, one of my favorites for this was the Altec Valencia. They just had this great range to cover violin sonatas combined with heavy orchestral crescendos. All of my Acoustic suspension and aperiodic speakers, although having excellent highs and bass performance, just couldn't match the ability to blossom freely. But, of course, the problem here is space. You just can't cram Valencias in a small room. You could try, but the room dimensions would probably give you standing waves and null points all over the place.
I've just gotten this system: monitor speakers and a powered subwoofer.
The models I got were the Polk Monitor 30's and the Polk PSW10 subwoofer, for my small 12x14x8 listening room. The room has a wall to wall rug, the control cabinet, a facing futon couch facing the system and a dressing cabinet on the side wall, so a guest could use it as a guest bedroom. The couch and the rug provide damping to keep those standing waves down.
I'm using my Kenwood KR6600 vintage 60 watt/channel receiver by using the pre-out,main-in jacks to supply the audio to the powered (50 watts) subwoofer. The speakers are hooked normally to the receiver, and get 60 watts/rms each(if you crank it high enough).
FM out here sucks, so I'll use CD, Vinyl or internet audio as my source.
Since I am recuperating from a serious illness AKA "Almost dying" I had to wait for my son-in-law to come out to help shove things around, so yesterday was the first day I was able to hear the system operate. I set the woofer to cross over at 80 Hz, the lowest setting, and gave it moderate volume. Vinyl, George Gershwin's Manhattan Serenade via Dual CS-501.
My first response was "JESUS!" I was really blown away by the sound I got in that room. Beeutiful! The only problem was once in awhile a small click was heard from the old album. It seemed to have effortless dynamic range.
I understand that you need to play and tweak the system by fiddling with the woofer volume settings to get the best balance, and I might add some volume to the sub today and see how it does, but the Monitor 30's made a great team with the PSW10 woofer. I could not detect the crossover point by hearing a bloom or dropout, so I guess the 80Hz is a good spot. The Monitor 30's are rated to go to 65 Hz cleanly and they have a great musical sound. The overall effect was a seamless crystal clear image without harshness, that you could easily crank up enough to blow yourself out of the room.
I'm not pushing the Polks, everybody has their own tastes, but I do feel a good subwoofer, monitor speaker system can be the way to go when you don't have the room for a larger system. BTW I am strictly a two channel man. Always have been and always will be.
Good luck!
