Not anymore.Many great deals at yard, tag and estate sales. I found both sets of my 3s at Good Will, 50 bucks, and Salvation Army, 19.99.
Oh you’re be surprised. In the AR FB group, plenty of finds have been posted.Not anymore.
The big classic ARs were highly dependent on room dynamics, because the dome tweeters need a big space with hard surfaces to create a reverberant field. Added to that, the 3 and its cousins with 11" woofers need a lot of power and amps that can handle impedances down to around 2 ohms. So if you have less than 100wpc to play with and a small listening room with carpets, heavy drapes and overstuffed soft furniture you'll probably never like 3s very much. The 2 series outsold them by leaps and bounds. The 5 was a happy medium for people with lower power amps and smaller rooms, but AR priced them badly; they were too expensive for the people who shopped 2s, so their appeal was mostly to people with lots of money and small rooms, except that people with lots of money tend to get big rooms.
Maybe in your part of the country. Not in the San Francisco area where I am. Have never seen 3 or 3a’s go for less then several hundred when they do show up. Not as common obviously as they are on the East Coast and my experience is people know how to get on a computer and do 5 minutes of research.Oh you’re be surprised. In the AR FB group, plenty of finds have been posted.
People who bought 5s generally had smaller spaces and were not trying to achieve the same loudness. Also, the 5 was an 8 ohm speaker whose woofer didn't dip down into the 2 ohm range the way the 3's did, so it wasn't as picky about amplifiers.The AR5 is actually less sensitive than the 3/3a, so needs more power, not less, to achieve a given loudness.
Classic era ARs were always more expensive and less plentiful in the western part of the US than in the east. AR had a higher list price "west of the Rockies" and a much smaller network of dealers.Maybe in your part of the country. Not in the San Francisco area where I am. Have never seen 3 or 3a’s go for less then several hundred when they do show up. Not as common obviously as they are on the East Coast and my experience is people know how to get on a computer and do 5 minutes of research.
I agree about them being less demanding from a load standpoint, but see no reason to think prospective buyers were those with smaller spaces.People who bought 5s generally had smaller spaces and were not trying to achieve the same loudness. Also, the 5 was an 8 ohm speaker whose woofer didn't dip down into the 2 ohm range the way the 3's did, so it wasn't as picky about amplifiers.
The 5 was an 8Ω speaker the 3/3a was a 4Ω speaker so different drivers although very similar.I had assumed that the midrange dome in the 5 was the same as in the 3/3a.
The 5's tweeter and mid were 8 ohm versions of the 4 ohm drivers used in the 3a. The crossover was a modified version of the 3a (more complex than the 2 series crossover), and the 10" woofer was also different from the 10" woofer in the 2ax, though eventually AR only offered one service replacement for both models. So it was more that the 5 was an 8 ohm 3a with a 10" woofer and a different cabinet.That's interesting - I had assumed that the midrange dome in the 5 was the same as in the 3/3a. And, in accordance with the common wisdom that the 5 was essentially a 2a with the 3 mid and tweeter, I hadn't considered that the cabinets might be different.
Thanks for the info.
