... My amp BTW is a Pyle 8000watt. I KNOW its not 8000watts ...
The rated power is probably 8000 W ILS -- If Lightning Strikes.
... but I also know its above 2000watts.
How do you know this? Have you measured it on a test load?
Well, I haven't had a chance to compare tubes to ss, but it is commonly believed that tube amps are louder than ss. Only one person claimed that 35 tube was louder than 100 ss which was posted on AK somewhere.
I don't know too much about tube amps.
For $200 I can get like 10 RMS per channel IF that. Why?
Why are they so low power per dollar spent? Do they use a different kind of RMS rating?
I'll give it to their looks but I'll be damned I spend $500 for 35WPC, just seems like a bad joke.
How the hell does anybody power a set of competent, powerful tower speakers with one?
Just seems impossible without paying your yearly salary.
THX specification calls for 105 dB peak and 85 dB average at listening position. Considering that most speakers are in 88-91 dB/W/meter range and you likely sit in 10 feet away, you will need about 500W, and this does not count for compression in speakers.
Consider that power output is not a cut-and-dried thing. To me, an amplifier is only as good as it's power supply. So would I rather have a 35 watt amp with a hefty, well-designed power supply, or a 350 watt amp with a "bare minimum" power supply? Obviously I would go for the 35 watt amp. That 35 watt amp would probably kick the pants off the 350 watter in every definable category, except (maybe) sheer volume output.
Unless you are trying to recreate a Whitesnake concert experience, the vast majority of listening is done at under 10 watts, and even a fair amount of that under 1 watt!
But if you really do need big wattage, a Crown Macrotech (or similar) amp is the way to go.
Just my WAG here.
First, it's marketed as "DJ equipment" for whatever that is worth, and maybe that's how they get around it right there.
Most stage and front of house equipment riders specifically preclude the use of junk brands like Pyle, Pyramid, Gemini, etc and bottom tier brands like Behringer, Alto, Mackie etc. So, i don't think the makers of true professional equipment consider the low enders to be a realistic threat in the marketplace.
I'm not sure the PILE amp could even be legally used in a USA venue, it does not have a rear panel mains fuse or circuit breaker.
If it really does sound good, and make halfway decent power, it's a shame that they don't represent it in more common and honest terms.
Ludicrous claims of 8000 watts output for 300 bucks new will, and should raise the brows of doubt for most folks.
Now watts do make some difference but not nearly as much as the quality of the power supplies (pound for pound better in good tube amplifiers).
Give us the time, open up your objectivity, and we'll put that fantasy to rest for you. You got what you paid for.When i bought my Pyle I knew It was likely I was getting way more than if I bought a Crown or Peavey
Spending the same money in the used market, with a little guidance, you would have Crown, Ashly, BGW, or Crest amplification, more power, far more reliability, and resale value close to what you paid years down the road. Careful buying in the used market will get you all your money's worth, and a bunch of goods that somebody ahead of you paid for.
The FTC stated specs, published laboratory test results, and history of developments and patented technologies tell me ALL i NEED to know about any amplifier before i take the time to audition or implement it into a home system, portable rig, or any other application..Do you own my amp? How do you know ANYTHING about it? Assumptions here and there unless you own or have heard this specific Pyle...
Well... Its pretty sketchy as always.
Based on price I can ball park RMS ratings in car audio.
For example, parts only come so cheap to manufacture so there's a roof in a price range for RMS power.
For $100 your usually dipping into 300-500RMS, $200 $800-1200Rms.
Unfortunately I haven't bought and installed enough home power amps to know.
If the home audio/PA amp game is at all the same, I suspect a no name, cheap Technical Pro, Pyle, Gemsound, Behringer, would beat a Crown amp to death for what you pay and how much power you get.
I'm guessing $100 150-200RMS WPC. $200 200-400RMS WPC. And above $300 you can get 1000RMS in a CHEAP Behringer or Pyle.
How about sponsors? Got any sound contractors, recording engineers, or artists promoting the Pyle amplifiers?
Your amp has none of those.
How deep do you want to dig in this hole?
You must not follow many threads on AK if you think this one is a sh**storm!
And, the LFE channel is +10dB to that stated above.
So, more detail it goes like this...
The average levels for movies are recorded roughly -20dBFS, and reference level is 85dB. So, when the content of the movie soundtrack peaks at or near 0dBFS recorded level, the system should be able to respond accordingly; 85dB + 20dB = 105dB. And, again, +10dB for subs. Some say the sub requirement is actually understated because of the bass management redirecting low bass from other speakers to the sub in addition to the actual LFE content.
You're the only one questioning them.I've heard nothing but assumptions from you.
That's good for 8000 watts?Oh, and bring up sometime about speaker wire.
I understand the point you're trying to make in this regard in this thread.
But, generally speaking, you don't actually get the watts if you don't have a good power supply. So, it's like many things where you don't get one without the other.
Unfortunately, watts have been misunderstood to equate to volume. They don't. But numbers are easy to sell. Sound Quality is not easy to sell because in mass market chains like Future Shop and Best Buy they don't have the space to dedicate to serious listening - nor do they want to spend the time convincing (educating) people. So a race for most watts began.
It is no different that cameras touting higher megapixel rates. A camera with an excellent lens/lens sensor with 4megapixels will beat a camera with 30 mega-pixels and an inferior lens/lens sensor. But numbers are easier to sell - A has more than B so A is better.
Volume is a function of SPL in bels. decibels (dB)
On the back of a speaker you will see the SPL as something like 87dB sensitive 1W/1Meter. The speaker will produce 87 decibels with just 1 watt at a distance of 1 meter (this is actually pretty loud)
Very loud is 97dB is very loud and 107dB would cause most people pain (and continuously would cause hearing damage.
Why?
Well it takes double the watts to get a 3dB increase in volume level. So a 100 watt amp will give you a 3dB increase in volume level over a 50 watt amp, but 3dB isn't that noticeable (Ie; not very audible). To actually notice a DOUBLING of perceived volume level it takes a 10dB increase.
So let's use the 87dB speaker
1 watt = 87dB
2 watts = 90dB (doubled the power to get the 3dB increase)
4 w = 93dB
8w = 96dB
16w = 99dB
32W = 101dB
64W = 104dB
128w = 107dB (most loudspeakers have a max watt rating and it is usually in the 100W - 200W range) and most speakers (especially small standmounts peak at 108db (so having more watts than the speaker can handle is worthless)
256w = 110dB
512w = 113dB
1024w = 116db
Now with these speakers and say the 10 watt amp you will get around 97dB-99dB (because most good amps can offer up peaks above their rated output. Again this is very loud - but in a big room you might want more - but the above speaker may have trouble regardless unless it can handle a lot of watts (and again most speakers can't).
But if you notice there is another way to achieve dB and it has nothing to do with the amplifier - that is Speaker Sensitivity.
If you have a 97db sensitive speaker you can redo the chart above and now with
1w = 97db
2W = 100dB
4w = 103db
8W = 106dB
16W = 109dB
With the speaker above you would need a 250 watt per channel amplifier to achieve the same volume as a 16 watt amplifier will put out with this 97dB speaker - but remember most speakers can't handle the 250 watts so the above speaker with the 250 watt amp will be blowing up. This 97dB speaker will barely be working hard and it will be pelting the volume at you.
Do it again with a 107dB sensitive speaker and
1W = 107db
2W = 110db. So with just 2 watts you are beating or matching the 97dB speaker with 16 watts and the 87dB speaker with 256 watts.
Yup a 2 watt amp putting out the same volume capability as any 256 watt amplifier. All depending on the loudspeakers.
Tube amplifiers - Particularly SET(Single Ended Triode) amplifiers offer a number of advantages. The mains one being class A operation, are linear (if SET) and have no negative feedback. Negative feedback is a kind of error correction - the problem is that the errors occur before the feback loop is engage and the errors get passed through to circuits many multiple of times. Measurements are reactionary and take the input after the feedback loop is engaged not before - so they look good on the graph (but the reality is masked.
There are a few good Solid State design out there that are also Single Ended topology. The longest selling integrated amplifier in the word - the Sugden A21a is ~20 watts class A no feedback amp and doesn't double into 4 ohm loads - indeed the power drops to around 12 watts. And it runs very hot.
So what you need to say to yourself - gee they've been selling this amplifier since 1967 and it always wins the blind level matched panel listening tests in the British press. (people choose the Sugden when the level is matched and no one is allowed to see what the amps look like) Cause if it looks ugly and has no features and it's hot and a bit pricey and only 20 watts - it has to have SOMETHING going for it right? Ahh Sound Quality.
And most of the guys under about 50 who own SETs began with Solid State. Most of the elite high end today is Single Ended Triode and various other low watt no feedback designs. Indeed even some of the top SS manufacturers when listeing blind have chosen low watt tube amplifiers over their own pricey SS amps. http://www.stereophile.com/reference/70/
