I LIKE MUSIC
Clipping.... raises the DC content in the signal
I mean no disrespect, my OCDness makes me do things like this.
There is no DC content in a clipped waveform (regardless of what it looks like on an oscilloscope), it still remains a complex waveform''
If the output voltage stays the same, the power will increase because of a change in the crest factor of the waveform. A fully clipped sine wave (which may become close to a perfect square wave) will produce almost twice the power for a given load and output voltage as an unclipped sine wave..
BTW, for transistors that use sockets, it is not a bad idea to pull the transistors and clean the socket contacts and the pins of the transistors regardless of the performance of the heat sink compound.
