dc270
Now Off the Reservation
Recapping Tolerances
I respect your apparent authoity here. Are the tolerances cumulative if one uses caps combined to equal a given value? I would presume they would be, but then again I am asking you to be certain.
Yout thoughts on using a "bypass" capacitor as JBL uses it. IE like a .15 uf cap or so used in the upper freq. part of the xover to aquire a better transient responce.
Thanks
DC
lorne said:Capacitors in parallel, where Ct is the total capacitance: Ct= C1+C2+C3 ... Cn. Each cap will see the same voltage, and its rating will remain the same as specified on the jacket. (But for future reference, be aware that the maximum voltage that can be safely applied to paralleled capacitors is limited to the lowest rated cap in the configuration).
220uF seems a really big cap value! Is the stock cap a non-polar/bipolar electrolytic? (I'm betting that it is.) If so, and if it is on the woofer, you might be OK with another electrolytic. But someone should analyse the network circuit and advise you on whether or not it would be worth stacking up film caps. I would ensure that the voltage on each cap is at least the same as the original, because AFAIK, the voltage of an electrolytic cap can be commensurate with the performance and behaviour in the circuit. (Whether you would actually “hear” mismatches is another question). I would also match brands and the cap's specific series. This will be printed on the jacket in the form of an alphabetic code or series number. I've had no experience in network substitutes or replacements in excess of 50uF.
Thanks
DC
