lorne said:
Hi Pyrrho: I am respectful of your opinion and would agree with you up to a point. Replacing parts with similar ones is not likely to produce gains. And the "psycho-audio" factor is something to be seriously considered — a metaphorical placebo effect. But I would submit some things that have been discussed above remain:
(a) In something less than a decade, bipolar/ non-polarized electrolytic capacitors having virtually no DC voltage applied to them will be in a state that is less than their original or optimal state.
They don't have to be perfect to still perform audibly identical to perfect ones. If they are reducing the signal to one of the drivers significantly, this will be audible. And if they have altered the crossover frequency significantly, such that one is worried about damage to drivers (as has been mentioned by others in this thread), this, too, will be audible, as speakers tend to audibly distort before they are damaged. If one hears a problem, then one should fix it. But if there is no audible problem, then it really doesn't matter, right? I personally own two pairs of speakers that are about 35 years old, which have all original capacitors, and I have noticed no problems. However, over a decade ago, I had to replace the capacitors in a pair of speakers from that same vintage, because they were causing audible problems. (In other words, I replaced capacitors that were "only" about 25 years old.) The lifespan of capacitors is variable, depending upon the original construction, and, of course, what has happened to them since then. Regardless of how old or new something is, if it is malfunctioning, it should be repaired. If it is not malfunctioning, "repairing" it is a waste of resources.
Of course, one may wish to modify someone else's design, which may be done at any time. But before doing that, one should really know what one is doing.
Now, obviously, since I have not made an identical crossover with new capacitors, I cannot be certain that there would be no audible difference if I were to replace the capacitors in the speakers. But on the other hand, I cannot be certain that the woofers are performing exactly to spec, or the tweeters, etc., either, without doing some proper testing of them. But no one is advocating that I replace these simply because they are old. That is what I am objecting to doing: Replacing things because they are old rather than replacing them because they are malfunctioning. Sure, capacitors are more likely to go bad with age (forgetting, of course, about foam surrounds on some speakers...) than other components, but they need not be replaced until they have actually gone sufficiently bad to cause an audible problem.
