honestabe316
Oh Chief! - Jane Hathaway
I have seen the ocassional silverfish over the years. I was not aware that vinyl was a "pooping ground" for the little buggers..
I have seen the ocassional silverfish over the years. I was not aware that vinyl was a "pooping ground" for the little buggers..![]()
OK, what is this "Scrubbing Bubbles"? Not sure if it's a mainstream product in UK. A quick Google shows a whole variety of products with that brand name, so which one are we talking about?
I've recently been asked to do a few vinyl-CD transfers for a friend. One of them was a well-worn 7" of "Blame It on the Boogie". Four gluings later, no improvement whatsoever in surface noise. Looking at the waveform in Audition, there were small spikes predominantly on the left channel - but what I don't understand is how these spikes - suggestive of debris in the groove - can be due to wear caused by uneven side pressure. Maybe they're somehow bedded into the sidewall?
Scrubbing bubbles is a foam bathroom cleaner....its in an aerosol can and cheap. Its been around in u.s.a. for years...you spray it and the foam expands and fizzles....I think if I get brave enough to leave it on for more than two mins, it might do a great job. I think the hard debris in the grooves just needs time to absorb the liquid and soften to the point where it brushes or rinse away freely.I bought the original formula
Yes, I have found that some records need more than one gluing,usually 2 cleanings is good enough.
I have done one record 3 times and I still can't get it clean.
I think it is one that may need an ultrasonic cleaning, nothing else has worked on it.
Mark
Need some help on this somewhat serious issue. On many of my wood glue cleanings, after peeling it off, I get a few very small, thin bands of glue that don't come off. This typically happens at the inside edge of the glue near the end of the groove (towards the label). This tiny amount of glue is very difficult to remove. I tried 91% alcohol and a q-tip, but all that seemed to do is spread the glue around. My Discwasher wouldn't take it off either.
Anyone else have this problem?
Just reglue, and this time, go heavier. Also, what slpcorner said. I've used scotch tape to lift some pieces, but it if is really bound to the record, you'll have to reglue.
Hello, I've read some pages of this thread but 128 pages would take me too long. If I can ask a question, once the glue is completely dry, meaning no yellow areas at all, all of it transparent, can I peel it off right away, or is it better to wait a few more hours?
I have done it both ways using Titebond II. Now I let it cure about 6-8 hours after it turns clear, basically overnight. What I found was, peeling right away after it turned clear, in 2 or 3 hours, left a residue down in the groove which would build up on the stylus on the first play or two, or three. Letting it thoroughly cure down into the depth of the groove works much better for me. Re-gluing and letting it cure overnight removed the residue from those records I had problems with after the 2-3 hour early peel. So no loss.Hello, I've read some pages of this thread but 128 pages would take me too long. If I can ask a question, once the glue is completely dry, meaning no yellow areas at all, all of it transparent, can I peel it off right away, or is it better to wait a few more hours?
