Worth 200 bucks?
If you get the "bookshelf" version that bobrown14 posted above, you HAVE TO do some simple tweaks:
1. First and foremost, take that big AMT unit OUT of the front baffle, and mount it ON TOP of the speaker. Experiment with the placement front-to-back, until you get the right location for optimal phase --your ears will tell you when you've found it.
2. Then EITHER plug up the hole where it came out, and continue to run the speaker as a two-way, OR (much better):
3. Get a good, fast mid-bass driver to put where the AMT came out, and re-configure the crossover to make the speaker a 3-way, something more like the rock monitor.
Even if you don't do the last part, AT LEAST move the AMT unit on top, as in step 1 above. You won't believe how much these speakers improve, just from this one tweak. It's like night and day. I know; I've owned two of them and done it to them both (before eventually converting the boxes to something else and just retaining the AMTs for my line-array project using them).
