Ouch. Well, still worth trying a solvent before throwing it away. A couple google results indicate acetone should soften the glue a little, but still won't loosen/dissolve it. You would need a urethane solvent to really get it off. No saying what any of those will do to the cone though until you try it.View attachment 1324425
This stuff is hard as a rock. There's no getting it off. Now that I look closer, it may be spray foam.
I'm not going to waste anymore time trying to repair the originals. I ordered new ones. However, the speakers are indeed worth it; they're well made and seemingly contain good components. I've seen named speakers constructed a lot more cheaply than these. They sounded very nice before all of this, nice enough that I had originally planned to put them into the rotation.
Interestingly I bought these at an estate sale with a bunch of albums, a turntable, cassette player and another pair of no-names. I opened those up and they were filled with early Jensens. These sounded better. Ended up selling those speakers for more than I paid for the whole grab. Not too bad.
Naphtha would be better if so.If you want to try it carefully, gasoline will dissolve spray foam. Just be careful
Your speaker became a mummy ? Poor woofer .... never saw anything this wildLord Amighty, it's worse than I thought!
If the resistance is measuring 6 ohms they are very likely 8 ohm drivers, you should be good!
