2 -- Based on the tube layout diagram in the Fisher service manual for the X-202:
1. V1 and V2 (12AX7) are the phono preamps for the left and right channels respectively. These tubes are only used when you are using the phono inputs.
2. V3 (12AT7) is the 1st stage line amplifier for BOTH channels. Used for all inputs EXCEPT the Tape Monitor inputs.
3. V4 and V5 (12AT7) is the 2nd stage line amplifier for the left and right channels respectively. Used for all inputs.
4. V6 (12AX7) is the tone control amplifier for BOTH channels. Used for all inputs.
5. V7 and V8 (7247) AF amplifier and Phase Inverter for the left and right channels respectively. Used for all inputs.
So, some tubes affect one designated channel, while others affect both. Good luck with it!
Dave
