I think I will replace them just for piece of mind.
Here is the B-1, I will strip everything.
If you're really interested send me a PM.I'll take 4 please![]()
Thanks, but I already have the manual. What Vint Age shared is a flier.This is also a great copy: http://sportsbil.com/yamaha/b-1-om.pdf
I was gonna say..
Yes that is the way to go. That is what I did with my unit for the Quickie, albeit, I would not call it a full rebuild.
The next B-1 I will do 'll be my Hot-Rod B-1 with silver front plate. That will be a full rebuild. I plan on eliminating all but two of the relays, by pass all input switches and the rumble filter, new speaker posts, a proper power cord for 1kVA and I even found a good cleaning "solution" for all board edge-connectors
Yes I knowThanks, but I already have the manual. What Vint Age shared is a flier.
Do you have it in higher resolution?I want it!Yes I knowLet me know if you also want a high-res digital copy of the B-2 flyer (German unfortunately) or the NS-2000 flyer (English).
I have the original B-2 flyer in English. I can shareYes I knowLet me know if you also want a high-res digital copy of the B-2 flyer (German unfortunately) or the NS-2000 flyer (English).
I want it!![]()
Yes please.NS-2000?
continued...
View attachment 1064080 View attachment 1064082
here I committed the ultimate sin by a certain someone's standard in terms of replacement components choice....I promise to repent
also...ran out of silver heatsinks so I went to black instead.
View attachment 1064095 View attachment 1064098
on the driver boards I will replace all carbon resistors and ALL caps. I found some of the R&Cs way out of spec. I already started the process.Waiting for parts...
Other changes I did so far was to replace all known trouble maker semis such as the 2sc 458s on the PSU boards and the 2sa810s on the driver boards.
will scan it for yaMy German is not so great, so yes please![]()
KSC3503D/KSA1381E (no longer available with same rank)
or
KSC2690AY/KSA1220AY
either would work
The first pair no longer available with same rank
Second pair a bit higher Cob than the originals
Either would be work and be more reliable that the original
These are TO-126 devices so watch the heigth. Also know that I have a patent on those heatsinks. Can't use the same kind without special permissinon
your only choice is to go with a la Amp8 version
What will special permission cost me?makes a good Sunday afternoon read,This "quickie" is becoming a "long read"![]()
I am thinking maybe you could find out for us if those C rank SK180s of yours need further matchingFantastic,
Cheers.
Those are nice heatsinksWhat will special permission cost me?
