Thanks!
I have 4 more usable 2SK180 to get another B-1 working if 1 should find its way to me ...
I am hoping to find one that does not need them
Thanks!
Would you care to discus what mods are needed to get the 2SK180 to work? It has quite a LOT of added input capacitance
Nick, in our correspondence you mentioned that resistor value changes on the driver board were needed when using 2SK180's to replace 2SK77's which are lower Mu devices. Would you mind sharing that information in this thread?Thank you for your interest. I have followed your V-FET comments on this and other forums for several years and I'm looking forward to anything you'd like to add to help keep the B-1 amp working into the future. To my thinking the B-1 is a very unique amp that deserves to be preserved. A working B-1 is far more desirable than a dead one even if it doesn't absolutely meet the original full B-1 specifications.
The higher 2SK180 input capacitance doesn't appear to be an issue for the 2SK75 drivers so no mods were required for that. The amp is stable and working as it should. It sounds superb to my ears albeit they are getting older and perhaps a young set of ears might be able to notice a bit of frequency roll off beyond my hearing range.
The required mods are mostly to adjust for the higher 2SK180 device Mu in order to maintain an equivalent nominal circuit operating current.
One of the more challenging parts of the process is ranking the 2SK180's into usable pairs. For that you need a good sampling of 2SK180's and a curve tracer capable of displaying curves in the region of interest.
it is the difference in mu and the actual curves that require adjustment to the bias and balance range. Don't have the B1 schematic close by but if I recall correctly it's the values of resistances around adjustment trimmers that need changing (perhaps trimmers themselves).
Hi clinic,Hello Vintagejapan
I have refixed 3 B1 in 2015 and will do 5 in 2016 . It is a very long process to do but all were working well with 100% original V-FET and my electrolityc PCB kit to improove reliability of this amp and avoid dammage on power V-FET when one 15000MF/100V is bad and may destroy output V-FET .
I never saw any 2SK1447 or 2SK1448 in a YAMAHA B1 ! are you sure it is not 2SC1447 and 2SC1448 ?
Hi clinic,
I would love to get a couple of those if you have spares
I can say it is very good too ! I know because I have tested them in real conditions !
What caps are you using in your kit Vintage?Thank you clinic! Yours does look very nice and maybe it might be a little easier to fit in than mine¿. You will have to send me one to try.
Mine uses 4 18000 uF/100V 105° C caps but 85° C caps will also work since they are located away from the heat.
I think we love the B-1 more than most to go to so much trouble to make them work for many more years.![]()
And yes, I do love the B-1. I have come across and own few other pieces but still keep coming back to the sound of B-1.
To my ears it does sound sweeter than my other monster MX-10000 although the MX-10000 can drive anything with ease
