More LED trivia
For C-1, the original incandescent bulbs need to dissipate about 5 watts, hence the intense heat at the front of the c-1 above the vumeters
Also, the light is concentrated in the middle of the dial.
With the LED strip, light dispersion is significantly improved
And the heat dissipation is reduced ~20x
The installation is not necessarily difficult but it is not drop in either
For best results I daisy-chained the two LED strips 5v x 2 which can be powered up straight from the rectified 8v AC of the original feed to the incandescent lightbulbs. This is done in the new PSU of the C-1, in my case, but can be done as standalone with not too much hustle.
Now let’s talk about B2 and UC-1 LED strip conversion
For both applications I am using 12v LED strip
Because I need a flat surface to attach the strip to,
I made an adapter - the adapter varies between the B2 and UC-1 but it serves the same purpose
The B2 solution requires clipping onto the chassis, where for the UC-1 I am able to use existing mounting screws holes.
The end result is the same: a flat surface to mount the LED strip
I will eventually carve this out into its own post about mounting strip LEDs but for now, it should provide enough direction for the curious minds.
