Do I reinstall TR632 before I remove TR634? Or have them both removed?I'm thinking D311 is possibly bad . Remove TR634..and re-assess the previous voltage measurements and confirm my suspicion .![]()
No..TR632,633 and 634 are crowbar transistors .Designed to shut down the power supply if a fault occurs.Do I reinstall TR632 before I remove TR634? Or have them both removed?
What is actually installed ?When finding a replacement on mouser, what am I looking for? Service manual in one place says 2SA941 and the other says 2SA777
Oh yea, these things have numbers printed on them. 2SA941 BLWhat is actually installed ?
How did you test it ? 6 - way with a multimeter ? Component tester ? Hammer check..Tested TR628 out of circuit. Pretty sure it's shorted.
?Yes.. I have seen this device at this application induce a nasty noisy buzz into the +/- 30vdc power supply..Should I pickup some 1N4148 diodes as well (as noted above)?
Got some very low voltage numbers like .002 for some of the measurements. Seemed bad to meHow did you test it ? 6 - way with a multimeter ? Component tester ? Hammer check..?
Leave TR632,633 & 634 out of circuit until further notice. If there is and issue with the power supply . These three transistors will shut down the power supply.( ie. crowbar )Reinstalled TR632 and TR634
Still the same issue ?TR632, 633 & 634 are now removed from circuit
Remove D308 and D312 -- test them out of circuit. Better yet -- swap them out with a couple 1N4148's.If TR628 is 2SA777 (based on service manual) then measurements are
E -.93v
C -43.2v
B -1.2v
No, the power lights stay on now at front of the unitStill the same issue ?
That's some good news..No, the power lights stay on now at front of the unit
