Jake O Bob
D308 and D312 are this 1S1555 diode. Do I replace each one with 2x 1N4148's in series? or do I replace them 1:1?Remove D308 and D312 -- test them out of circuit. Better yet -- swap them out with a couple 1N4148's.
replace them 1:1?
Re-measure these voltages please.Measure the emitter voltages of TR626 and 627. Looking for + & - 30vdc..
Polystyrene -- easily damaged by heat including solderingclear/silver capacitor
What part # did you use for TR197.I had replaced R261 along with TR197 a few weeks back.
Since I'm new to this, I'm including photos of my measurements. Think I'm doing this correctly. Following this link for transistor measurements with MM in diode mode:Pull and check/re-check TR195 & 197
Shaped like this with a rounded back2SA673 sub
https://www.mouser.com/ProductDetail/onsemi-Fairchild/KSA1013YTA?qs=ljbEvF4DwON6KcAiegZDyA== sub
Is your 2SA673 shaped like and " outhouse " ?
These may be ECB instead of BCE...Shaped like this with a rounded back
Going off the service manual (unless it's misprint ?)These may be ECB instead of BCE...
Looks good to me...I picked up one of the cheap transistor testers. Just not sure what the screen result means since it didn't come with a manual.
This is the TR195. Should I assume if it does NOT say it's broken, then it tests OK?
Anything else I should be pulling to check? These 2 are testing good with the new testerPull and check/re-check TR195 & 197
