Well the Direct Disc switch is working, sort of. I'm using my SOTA with Monster MC cart. Got it to play, but the load switch has to be on MC, too. Thought it bypassed this switch. And, with the DD switch on, I can push the other input switches and it stays on the DD as it should, but if I move the load switch to MM, it cuts out. Also getting an intermittent hum. I can move the preamp or cables, the hum drops in and out. It did not have hum with my HK preamp or when plugged into ether Phono 1 or 2 on the C-50 without a ground wire. Going to take it apart again tomorrow and see if I missed something when I was deoxing & cleaning.
