Wrong power supply... Look at the (Muting & Power supply) circuit. Post a snippet of that schematic.View attachment 3345764probably staring right at it but don't see it.
ok block diagrams are a good zoomed out view - will start looking at them too
Top and bottom covers off - on the bench I have a copper wire running from front and back of chasis to the middle piece with gator clips. Still will checkIf bench work sends me to a world of confusion or overthink...block diagrams bring me back to earth.
Recommend checking chassis ground screws on the boards for tightness, I think they're copper and strip easy IIRC.
Getting close
So they’re ±15V and in this case powering IC309 (op-amp) on tone control 2 (new continuous loudness), I guess. Worth checking IC309 supply pins (5 & 9) to make sure it’s working properly. If you measure anything other than ±15V, then the IC is bad. I had a similar thing on my C-6 a while back.Right below TR341 you will see 4 traces. Your two wires ( red & white ) connect to, two of the four traces. They directly connect to the emitters of TR341 and TR340.
The OEM 4558 is and SIP. Your selection is a DIP. Would need and adapter board.
Yes … I copied and pasted the first thing I found in Mouser, not sure if they have SIP as well or not. If not, an adapter will do the job.The OEM 4558 is and SIP. Your selection is a DIP. Would need and adapter board.
Measure the power supply voltage at the emitters of those two transistors. Expect around + 15vdc & - 15vdc. This same supply voltages are used in a few other circuits as well. I doubt if these two pass transistors are the problem.Maybe it's worth it to pull 340 and 341 and test out of circuit
The schematic shows those two emitters (Tr340e/341e) at ±15.6V. Am I missing something? Where do you see ±40V? You’re right, probably not the problem here.Measure the power supply voltage at the emitters of those two transistors. Expect around + 40vdc & - 40vdc. This same supply is used in a few other circuits as well. I doubt if these two pass transistors are the problem.
My-bad...I was looking at a very poor-quality scan at the time of posting.Where do you see ±40V?
Typo...I was looking at a very poor-quality scan at the posting time.
