nj pheonix
Lunatic Member
Its 40 yrs old. If you can hear the difference (and like it) run class A. They were designed to be run that way.
OK, still early days, but what are listening impressions. In particular phono, compared to the CA-1000 if possible
Are you saying you used KW's in filter cap positions?Following up on Nichi KG's. I did my "training" on a NAD3150. Did almost everything to it, still sounded ordinary.
Swapped out the KG's for KW's and a veil lifted
Yes, in the NAD3150, they have 2 for each rail, 4700/63V. Used KW 6800uf/63V. Need to keep an eye on the ripple,Are you saying you used KW's in filter cap positions?
Thats very close to any pioneer receiver from the 70's...my SX-636 has almost all of those in it.Here are the numbers
2SA673A
2SA777
2SA872
2SB537
2SB566ANS
2SC1213A
2SC1509
2SC1775
2SC1918
2SD381
2SD476ANS
2SD526
Looks beautiful, nice work!
Very even spread on that lighting too, worth the fabrication efforts.
How does she sound?
Second that. Nice clean work.Looks beautiful, nice work!
My philosophy on my CA-800/-1000 is to use class A all the time, except on background "noise" duties. The ripple will be tough on those Nichi KG type 1's(?) and you may need to replace them a little earlier, but that's a small price. To be honest I don't really like the KG's, they were upstaged by KW's in smaller gear. I'm trying United Chemicon and boutique (Mundorf) in my next projects.
The NAD 3150 was probably my first refurb, recapped with cerafines and KG and FW for preamp psu.I've heard you say this a few times now so I'll bite - did you give them plenty of time to settle in?
Were the comparisons done with nothing else changed?
I tend to think that the amp is powered by the main caps and that the AC and rectification just charges up the caps. So it's theI can't really imagine how they could have much impact on sound
I think Yamaha amps, particularly the higher end ones use many stages of local capacitance to feed transistors, and as a result, in amps like the one in this thread I would think that the local capacitance makes a far bigger difference. On lower end amps the main filter capacitance is much lower + without running in Class A there is a far more variable load on what is potentially insufficient capacitance - which is why a lot of those low-to-midrange amps have audible benefits with main filter cap upgrades. No doubt for the same reason they are more sensitive to their performance too.I tend to think that the amp is powered by the main caps and that the AC and rectification just charges up the caps. So it's the
energy in the caps that used to amplify the audio signal from mV level to a "few" volts. OK this is just a basic understanding...
